Home > Maintenance & Mods (L322) > 4 Wheel Alignment |
Had mine done when the front lower arms were replaced. The drive is so much better now. I did put new Contis on the front as the existing ones were at 3mm. Picked up a little on the mpg but doesn't tramline, no noise, just a way better drive. Definitely worth doing. |
10th Jul 2016 7:18am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Dalziel....Kwikfit use the Hunter system in some branches ( call to check if your Harrogate ones do as its usually bigger branches) and that seems to get good reviews...think it's around £45 ( free if no adjustments needed). GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
10th Jul 2016 8:34am |
