Home > Technical (L322) > What is this for???
Stebo
2003 Range Rover Vogue 4.4 V8 Giverny Green
What is this for???
Right, see the button on the bottom left just below the analog clock, well what is it for???
It's my car btw and when this button is pushed in the light on the button illuminates when I put my lights on full beam. I was guessing that it was maybe for spot lights or something but my car doesn't have any Question Question Question
Post #15636 25th Mar 2010 2:05pm
dan_uk_1984
Maybe it used to have spot/fog lights - judging it has a picture of a fog light on it..... Considering it's a non standard switch I doubt anyone here would have a clue.
Plus why is your Auto Recirc light NOT illuminated? Or your A/C? You'll get electrical gremlins and your headlining will fall off...
Post #15637 25th Mar 2010 2:37pm
Vogue
whats the one on the right for too, never seen that one either...
Post #15638 25th Mar 2010 2:37pm
dan_uk_1984
LPG
Post #15646 25th Mar 2010 3:03pm
Stebo
I was thinking that it maybe used to have spot lights. Just thought I'd check incase it was a factory option, the button is very OE looking.
Thanks anyway, are you serious about not having autocirculating on causing problems!! Shocked
I was only sitting in the car and was checking all the button bulbs were working, normall I have it just facing the window
Post #15647 25th Mar 2010 3:14pm
dan_uk_1984
Auto recirc senses pollution in the air and closes the exterior vents - this is fantastic and should just be left on A all the time.
The range rover has Climate Control, part of this is the A/C system that de-humidifies the air to keep the interior comfortable and will mean the windows never steam up. It has the added benefit of making sure than the copper circuits in micro-switches (which ever switch uses) don't go green and stop working, as well as all the various electrical connectors.
Within 3 months of my A/C failing on my P38 there were electrical gremlins all over the car and the headlining started falling down all over the place as well as all the rubber around the windows developing mould....
Dan
Post #15649 25th Mar 2010 3:25pm
Vogue
the thin strip panel that these two swithces are located into - is it removable then?
Post #15650 25th Mar 2010 3:28pm
As Dan says the Air Conditioning should be on at ALL times. Make sure both lights on the control knob are on!Just because the A/C is on does not mean its cooling so set the Temp at your desired heat and then choose how cool you want the facial vents using the thumb control in-between the vents. Thumbs Up
Post #15654 25th Mar 2010 3:45pm
Vogue
I might be dumb, but I have read and re-read the handbook and I still cannot grasp the difference between one light being on and two being on in the dial - please please can anyone explain in easy to understand language without overly explicit terminology Very Happy
Post #15659 25th Mar 2010 4:04pm
I believe one indicates the system is on and the other indicated the Automatic Climate Control is on. Turn the blower dial manually and you lose the Climate Control Light! This is what my wife keeps doing so I have to beat her regularly Laughing
In other words unless both lights are on the car will not maintain the heat required or condition the air. It will simply blow heat or cold at the fan level selected.
Last edited by Gazellio @ Prestige Cars on 25th Mar 2010 4:10pm. Edited 1 time in total
Post #15661 25th Mar 2010 4:08pm
dan_uk_1984
One is a dot which is auto fan speed and one light is a dash which is auto vent direction.
If its really hot inside when you get in if both are on auto the fan speed will start fast and point to the face vents and feet to cool you quickly. As it detects the temp come down it will slow the fan speed for you.
On a cold day it will start off slow and direct heat to the windscreen, then as the engine temp warms up it will direct the vents to screen and feet and speed up a little.
Hope this explains it for you?
Dan
Post #15662 25th Mar 2010 4:09pm
Looks like an aftermarket LPG switchover light to me.... Discovery 4 HSE
Post #15665 25th Mar 2010 4:20pm
Vogue
Dan / Gary, many thanks - could never figure it out from the H/B - I just assumed one was the A/C and the other recirculation. Too many options confuse me! I only just found that my lights look round corners - thanks to this forum - and I have had L/R and RR since 1973
Post #15670 25th Mar 2010 4:25pm
You should list all your Land Rovers in the signature section. Would be interesting to us junkies Thumbs Up
Post #15674 25th Mar 2010 4:28pm
Vogue
Post #15676 25th Mar 2010 4:31pm
