Home > Technical (L322) > Brake pipe corrosion
Page 2 of 3 <123>
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
had mot done 2 months ago advisary was front brake pipes corroded, backs not as bad but starting to, had major service last week, sytner nottingaham advised that both sets are corroded and cost £570+vat to repair
went back to Gordon lamb chesterfield who did the mot now quoting £200+vat to sort out both sets, so its booked in.
Post #192551 7th Jun 2013 3:30pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Slightly more here but there was extra work.
£250-350 inc vat is what people should expect to pay in total from any decent garage Thumbs Up
Post #192599 7th Jun 2013 8:35pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I had mine done by my Indy and they put in cupronickel lines for about 1/2 the price a main dealer quoted for oem.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #192660 8th Jun 2013 10:00am
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
i changed mine this year with a mate of mine, i roll of copper pipe and the unions £33 quid, 3 hours graft and all done.they corode badly above the rear near side wheel.
Post #222317 12th Nov 2013 6:18am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
taskam wrote:
I had two brake pipe failures during the last MOT couple of months ago ...one while the mechanic was driving the car to be tested Shocked , the other when it was on the brake performance machine Shocked Shocked
Spooky coincidence, or revenue generator?
Whats the location of this failure on the RR ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #222430 12th Nov 2013 7:54pm
Monty1
looks like the nearside front wheel area behind the arch protector
Post #222559 13th Nov 2013 5:15am
Best change all the pipes at the same time, saves doing them next year and the year after Thumbs Up
Post #222569 13th Nov 2013 8:50am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Monty's correct about failure location 2007 TDV8 Vogue SE Java Black
Post #222571 13th Nov 2013 9:04am
What unions are required?
I have the LR front and rear flexis ready to go on, but need to replace the long front to back runs? .
Post #222684 13th Nov 2013 6:50pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
After reading this article, I climbed under my Range Rover and looked: only little white corrosion, could clean them, and gave them some transparent grease, will see next month, BUT: my BMW 530d E61 from 2005 has the same problems, because reading about this common problem in the BMW-E60-forum, they are fully corroded, and at one part there comes out some brakefluid! The german TÜV (like MOT) doesn´t heard about this anytimes, because the pipes are not to see, they are under the plasic underfloor part! Will construct me and some other RR drivers new, perfect to fit, brake pipes now...
Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #241050 8th Feb 2014 4:53pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Hi
Has anyone done a write up on how to change the rear brake pipes?
Cheers Grant
Post #247558 11th Mar 2014 4:12pm
fisha
It's the same as any general brake pipe replacement guide you'd find on the web.
On my 4.4 v8, I replaced mine from half way along where the pipe runs front to rear by the sill. Then ran pipes backs to the rear suspension.
Hardest part was getting the pipe up and past the fuel filter / tank area.
I did mine with a basic pipe flare tool, a small pipe cutter and copper piping. It's all pretty standard stuff.
I think though I just bought genuine replacement pipes where thy run along the suspension arms. V8 or else ...
Post #250336 24th Mar 2014 9:55pm
supershuttle
Just got mine done front to back pipes at the Indy, it would have failed the MOT apparently. also had a new alternator fitted and rear suspension bushes done plus a turbo hose as well, all in just over a couple of grand with the MOT, service and loan of a freelander for 4 days.
Should keep it going for another 6 months Very Happy Geoff
Post #250344 24th Mar 2014 10:51pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I am planning to change mine, but can not see how to get them down the small gap just in front on the nearside wheel arch before they run parallel with the sill. I have bought pre-formed genuine parts and wondered if there was some trick to get them through the gap. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #250347 24th Mar 2014 11:05pm
Johnte
Just in the process of making some up in stainless steel, hopefully last a long time Thumbs Up
Post #250352 24th Mar 2014 11:34pm
Page 2 of 3 <123>
