Home > Technical (L322) > Brake pipe corrosion |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
Slightly more here but there was extra work.
7th Jun 2013 7:35pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I had mine done by my Indy and they put in cupronickel lines for about 1/2 the price a main dealer quoted for oem.
8th Jun 2013 9:00am |
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 |
i changed mine this year with a mate of mine, i roll of copper pipe and the unions £33 quid, 3 hours graft and all done.they corode badly above the rear near side wheel. |
12th Nov 2013 5:18am |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Whats the location of this failure on the RR ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
12th Nov 2013 6:54pm |
looks like the nearside front wheel area behind the arch protector |
13th Nov 2013 4:15am |
Best change all the pipes at the same time, saves doing them next year and the year after |
13th Nov 2013 7:50am |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
Monty's correct about failure location 2007 TDV8 Vogue SE Java Black |
13th Nov 2013 8:04am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
What unions are required?
13th Nov 2013 5:50pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
After reading this article, I climbed under my Range Rover and looked: only little white corrosion, could clean them, and gave them some transparent grease, will see next month, BUT: my BMW 530d E61 from 2005 has the same problems, because reading about this common problem in the BMW-E60-forum, they are fully corroded, and at one part there comes out some brakefluid! The german TÜV (like MOT) doesn´t heard about this anytimes, because the pipes are not to see, they are under the plasic underfloor part! Will construct me and some other RR drivers new, perfect to fit, brake pipes now...
8th Feb 2014 3:53pm |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
Hi
11th Mar 2014 3:12pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1351 |
It's the same as any general brake pipe replacement guide you'd find on the web.
24th Mar 2014 8:55pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3796 |
Just got mine done front to back pipes at the Indy, it would have failed the MOT apparently. also had a new alternator fitted and rear suspension bushes done plus a turbo hose as well, all in just over a couple of grand with the MOT, service and loan of a freelander for 4 days.
24th Mar 2014 9:51pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
I am planning to change mine, but can not see how to get them down the small gap just in front on the nearside wheel arch before they run parallel with the sill. I have bought pre-formed genuine parts and wondered if there was some trick to get them through the gap. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
24th Mar 2014 10:05pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Just in the process of making some up in stainless steel, hopefully last a long time |
24th Mar 2014 10:34pm |
