Home > Maintenance & Mods (L322) > Coolant Cap
JRCH
2003 Range Rover HSE 4.4 V8 Rimini Red
Coolant Cap
I have noticed a coolant leak after the vehicle has come to a stop, engine off and standing for a few minutes. There is coolant residue around the header tank so I have changed that. the cap has 140 stamped on it, I have a 4.4 v8, LPG converted, should this cap actually be the 200 version and if so could this be the reason for the coolany loos as it appears to be coming from that area?
Post #192210 5th Jun 2013 6:01pm
robjp
Wales 2004 Range Rover Vogue Td6 Zambezi Silver
I may be mistaken, but I believe the coolant caps are all 'stock' BMW ones that were fitted to every BMW, with no difference (apart from maybe price, if they were trying to sell you one for a 7 series, rather than a 3 series)
Post #192216 5th Jun 2013 6:50pm
Simple1
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
I'm not sure that the number relates to much. On steel caps there is usually a pressure rating but never seen it on plastic caps. If the pressure build up in the system is too great the valve will let pressure and some coolant out. By rights it should not reach that pressure so the problem could lie elsewhere. Thumbs Up
Post #192217 5th Jun 2013 6:59pm
The 140 is for the TD6. The petrol needs the 200 (280 maybe can't remember). If you're old cap was 140 rating that's why it's leaking. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #192228 5th Jun 2013 7:40pm
found using the search function,
http://www.fullfatrr.com/forum/topic12183....oolant+cap ... - .- -.
Post #192229 5th Jun 2013 7:50pm
Tuts
Seem to remember that discussion- there are 140 and 200 caps (the 280 cap that people talk about is actually a 200 with a bit of plastic retained from manufacturing process in the centre 0 which makes it look like an 8 (inside the cap the pressure rating is repeated).
I have a BMW 4.4 and have a 140. I worried when reading the above thread but I have never had any problems with leaks. If you do I'd suggest the fault (pressure build up) lies elsewhere and the cap is the first to show the excess pressure (as its designed to do(?)
The cap has been on there since the factory without any recall sso I'd say its fine at that pressure rating. 2003 Vogue 4.4 V8 Java Black
Post #192382 6th Jun 2013 4:59pm
