![]() | Home > Maintenance & Mods (L322) > Just to be sure. Steering clunk. |
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 ![]() ![]() |
I had a good look around the suspension this morning. With the wheels on the ground I can rotate the right, front ARB drop link just by grabbing it with my hand. The left front is solid.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35619 ![]() ![]() |
i think the spinning one is shot, but i'd replace both as the other one might go soon.. ... - .- -.
Yeah, sounds like a plan. Easy job so I'll do it on Saturday morning. 2006 FFRR 4.2 Supercharged Vogue SE
Hmm, I'm not convinced it's the droplinks now. I'll swap them anyway though.
lower ball joints ?
I don't think so. It certainly doesn't sound like it's coming from that area. 2006 FFRR 4.2 Supercharged Vogue SE
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I had the same and it was a lower ball joint, but I also had other symptoms of clunk after potholes and a loud squeal when turning wheel to the right. |
No other symptoms. It's just the clunk when turning the steering. 2006 FFRR 4.2 Supercharged Vogue SE
If replacing parts, it is going to be cheaper to work your way from the outside in towards the rack!
I did the ARB droplinks today and noticed something that didn't seem right to me.
Maybe the guy writing the record made a mistake or the mechanic went to the wrong side ?? MY 2010 5.0 SC Galway green and sand interior!!
It's possible. Both links are caked in crud but I didn't think to examine them closely to be certain which one has been changed. I'll get it up on the ramps tomorrow and take a look properly. 2006 FFRR 4.2 Supercharged Vogue SE
Well, the clunk is getting much worse now. I'll take it in to Rovertune when I'm back from holiday and get them to have a good look.
A user on here (remain nameless )who had similar found that a bottle of suncream in side pocket was making the clunk |
