Home > Maintenance & Mods (L322) > Just to be sure. Steering clunk.
Page 3 of 3 <123
Check your VIN.... This one covers up to 5A999999... Dan at duckworth should be able to help if you know your VIN. Thumbs Up Previously..
Post #193095 10th Jun 2013 3:36pm
Tayas
I'm a 6A****** 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #193105 10th Jun 2013 3:58pm
Tayas
Well, took it to another indy who diagnosed and replaced a trackrod end. Clunk now gone. �54 all in.
That's a lot better than the �2.5k I was looking at for the fitting of a replacement rack.
I will be taking to them again and will be avoiding the other place. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #194828 18th Jun 2013 9:14am
Laughing Experts, what do they know eh!! I hope you let your original expert know he misdiagnosed the fault ! Previously..
Post #194861 18th Jun 2013 11:13am
Great picture: (Anybody got the key...)
Post #223366 16th Nov 2013 4:24pm
from Rave, so a bit wonky but:
1
right-hand (RH) front damper assembly
2
RH tie rod
3
Subframe body mounts
4
Front cross link valve
5
Stabilizer bar
6
left-hand (LH) front damper assembly
7
LH tie rod
8
LH front hub assembly
9
LH lower arm
10
LH stabilizer bar link
11
LH front height sensor
12
Front subframe
13
RH front height sensor (hidden)
14
RH lower arm
15
RH stabilizer bar link
16
RH front hub assembly
17
Hardened washer (2 off) There is nothing that can't be fixed with a hammer😜😜
Post #223368 16th Nov 2013 4:50pm
Page 3 of 3 <123
