Home > Maintenance & Mods (L322) > Gearbox oil change or not |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 810 |
When you go through the gears......this is as straightforward as ensuring you apply the brakes whilst doing so? |
21st Nov 2019 8:14pm |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Yes absolutely. No need to allow the wheels to turn. It's simply to allow the torque converter to fill with oil so you dont under fill the transmission |
21st Nov 2019 8:30pm |
Thank you
21st Nov 2019 8:36pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
My fullfat rr is a tdv8 2012 4.4 which is probably due for gearbox oil/ filter change. Can anyone tell me if a special tool for removal / refit of the filler plug Is really necessary. A tool re Lange Rover no 307-452 is mentioned in despatches but MD at Bristol can’t / won’t supply?
17th Jan 2020 3:45pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Dave - take it to Cam Tech Craig’s place. Look him up on here Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jan 2020 4:11pm |
Thanks for that then , I’ll check thru the membership list. Been to wet etc lately to have a look under but a good time to plan the next jobs. Spoke to nearest MD and they quoted over £200 just for the sump pan?
17th Jan 2020 4:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35414 |
craig is your man,
17th Jan 2020 4:37pm |
Take it to Craig and relax knowing it will be done right and not at main stealer prices Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jan 2020 5:09pm |
Thanks for the link and found his web site. I’ll give him a call next week for a chat. Mislabel at 51000 but now seven years old .
17th Jan 2020 7:10pm |
