![]() | Home > Technical (L322) > lazy starting on a 4.4 V8 when warm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
http://www.fullfatrr.com/forum/topic17368....rting+warm
mattyboy Member Since: 14 Feb 2012 Location: Colchester Essex Posts: 28 ![]() ![]() ![]() |
so other people have had the same problem but no body knows what it actually is! |
As one of the former sufferers of this issue, I can tell you that for me the problem went away when the fuel system got the royal treatment. New fuel pump, cleaned injectors and cleaned inlet manifold.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
You could do worse than look for a leaking injector
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
i have this exact error with rough starting when warm, cold starts perfect no issues at all. There are no fault codes logged in the ecu have checked with my faultmate.
ive changed my fuel pump and fuel filter and the problem has now gone |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
Hy Matt,
