Home > General > Speed restriction on TDV8?
Page 2 of 3 <123>
The limit can easily be removed with a Faultmate and possibly an IID tool.
Literally takes a few minutes to do it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186973 7th May 2013 7:56am
I think the lowering is more to do with reducing the drag on the vehicle caused by the sheer volume of air going under the vehicle and the aero affect it causes Thumbs Up
It used to be 60mph which was sensible but fraggle rock knows why they had to make it so high when its very few countries it could get used it as it would have an affect on MPG as well.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186974 7th May 2013 8:00am
the 2002-2005 pre-facelift will go down to motorway height between 65/70 mph , the 2006 onwards apparently go down at 100 mph.. ... - .- -.
Post #186981 7th May 2013 8:19am
DMRR
The 2006+ do not lower - or if they do they do not indicate this fact. I have tried this on a 4.2SC, 5.0SC and 3.6TDV8.
Oh in regards the tyres, yes V rated say 149mph, but next time you run at 130mph, stop at a fuel station and either check your pressures or simply feel how hot the tyres are. I for one would not want to blow out a front at that speed. I also assume you are adjusting your pressures as per the handbook for sustained high speed cruising.... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #186998 7th May 2013 9:00am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
The 2006+ definitely do lower and it's marginally visible on the "off-road screen" but isn't indicated as anything special. You can just see the car sitting lower on that screen (similar to access mode). This is something I'd recommend you get a passenger to check though as you should be looking ahead when you're going that fast. It raises up after you've slowed down to less than 80 for about 30 seconds.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #187012 7th May 2013 10:13am
Philip
2006-2009 do lower over 100 mph although, as you say, there's no specific indication to say it has happened and the setting isn't separately available like on the early cars (from memory you can lock into motorway mode once it has automatically selected).
Tyres - if they're inflated to the correct pressures, are the correct size and have the correct load rating then given some common sense they should be safe for continuous use at the rated speed, whether they get hot, cold or somehwere in between.
Will be purely an attempt to improve high-speed handling by lowering C of G, thereby reducing body roll etc. Presumably the Adaptive Dynamics dampers of the 2010-on cars preclude the need for it.
Post #187014 7th May 2013 10:25am
^^ something i'm hoping to change with some more fiddling Smile
And well, 650kg per tyre at that speed constantly flexing and then some depending on the road should make a lot of heat, though nitrogen filled will also help a little for this.
I think the heat is more likely to cause rubber bobbling, especially on warm days. maybe fine if the temps are low but sustained high speed for them isn't something id want to try either, maybe a quick blast upto the speed would be ok though.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #187015 7th May 2013 10:28am
I've driven loads on the German autobahn, often in the middle of the night, and it's very rare you're able to sustain those kinds of speeds for any length of time, especially in a vehicle that takes quite a while to get there. You'd have to be nuts to go past a line of trucks doing 55mph when you're at 150mph.
At least on the autobahns I've driven on - maybe there are some totally deserted stretches some where.
I'd expect tyre manufactures to be conservative with speed and weight ratings anyway.
Post #187016 7th May 2013 10:57am
DMRR
My 2006 is already 20mm lower than standard across all modes to make it handle better in corners, are you saying at 100mph I'm riding AT access height-20mm? I think you will find I am not!
In the handbook you will find it states a mode change on the 4x4 screen. This DOES NOT OCCUR.
As for it pitching up again when you slow down, you can make that happen at traffic lights in 30mph traffic - caused oddly enough by braking. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #187050 7th May 2013 1:52pm
Philip
Pre-Terrain Response:
2006 Owner' s Manual wrote:
High Speed Suspension Height
This vehicle has a feature which lowers the suspension ride height by 20 mm if the vehicle exceeds 160 km/h (100 mph). The driver has no control over this and is designed to improve high speed stability.
Note: NEVER exceed the speed limits.
Post-Terrain Response, pre-Adaptive Dynamics:
2007 Owner's Manual wrote:
High Speed Height
This feature is designed to improve vehicle stability at higher speeds, and lowers the suspension ride height by 20 mm (0.8 inches) if the vehicle exceeds 160 km/h (100 mph) for longer than five seconds. This action is automatic and cannot be overridden. Ride height will return to normal when vehicle speed returns below 130 km/h (80 mph) for 30 seconds.
Note: Never exceed the speed limits.
As for what yours does, who knows? That's why it's best not to mess with things you don't understand. Access height is, however, 40 mm lower than On-road height.
Post #187074 7th May 2013 4:10pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Quote:
High Speed Mode
High speed mode is a non-selectable, automatic mode which lowers the vehicle height by 20mm to improve vehicle handling. This feature is fully automated and is 'invisible' to the driver.
If the vehicle speed exceeds 100 mph (160 km/h) for more than five seconds, the air suspension control module initiates the high speed mode. When the vehicle speed reduces to less than 80 mph (130 km/h) for more than 30 seconds, the vehicle returns to the On-Road height. This function is cancelled if a trailer is connected to the trailer socket.
Latest info from TOPIx about this.
Post #187085 7th May 2013 4:50pm
DMRR, what evidence do you have that the handbook is wrong on this?
Post #187092 7th May 2013 5:40pm
DMRR
I will ignore your arrogance. My information is based on actual experience. So, in my case, it doesn't lower, and never has. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #187169 8th May 2013 8:21am
DMRR
Sustained driving on the limiter across Germany on the way to Poland. No mode change indication occurred and the white lines didn't move lower to the wheels. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #187170 8th May 2013 8:22am
DMRR, i can only think that because you have lowered yours 'manually' then the ranges ecu cant lower it any more when you do go above 100 mph.. ... - .- -.
Post #187171 8th May 2013 8:26am
Page 2 of 3 <123>
