Home > Technical (L322) > rear light puzzle
ronco
rear light puzzle
hi, i'm asking this question on behalf of a friend who has a l322 autobiography. he said that oneof the bulbs in his rear light unit isn't working. he tested for voltage and said there isn't any, but he also said there is no voltage on the one that is working. how can this be?
Post #186448 3rd May 2013 7:22pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Possible "Eye Dee 10 Tee" fault on the testing equipment? Laughing 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #186453 3rd May 2013 7:43pm
Jonno
Seriously though, he needs to retest for the voltage or change the bulb. Lights do not work without volts. 5.0 supercharged autobiography
Post #186457 3rd May 2013 7:49pm
Depends as to which bulb it is, i gather its a side light? The side light bulbs do not work on 12v as they are 21w bulbs (not the usual 5w) commonly used, so the 21w bulba (usually brake, indicator or fog) are fed with approx 3-5v to get the same brightness...
He needs to swap the good bulb with the bad first...
Craig Thumbs Up
Post #186472 3rd May 2013 8:58pm
afaik the lights work via a pulse signal that 'switchs' on the 12 volt supply to whatever needs the power...if no bulb fitted [blown or new] then the pulse wont supply the 12volts to it..i might be wrong though. ... - .- -.
Post #186490 4th May 2013 7:58am
