Home > General > Potential new owner |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I had my 4.4 for just under three years and it left me stranded once and that was just toward the end of my tenture. I had replaced the alternator 4weeks prior and the new unit seized leaving me with no belt so now cooling. On the back of a flatbed and a new alt and all was good. Never had a flat battery or anything like that. Loads of maintenance but nothing that left me at the side of the road. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
29th Apr 2013 8:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
had a td6 for just over two years and never broke down once..
29th Apr 2013 9:07am |
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 |
Here's another question for you guys. Assuming the worst happened and the gearbox lunched itself, what am I looking at for repair or replacement? £2.5k ish? What about a suspension refresh (air bags, struts, compressor) £2k ish? |
29th Apr 2013 10:02am |
For that money there are some good SC's floating around, albeit with High Miles on but if you flush all the fluids and maybe swap the rad/gearbox cooler you should be able to get a decent one that will hold together for a while.
29th Apr 2013 10:06am |
29th Apr 2013 10:56am |
I had a Jag S-Type R with the 4.2 SC engine for a while. Lovely motor but I think 16mpg is too little to stomach. I need to be able to break 20mpg on a motorway run really otherwise when I drive business miles in it I will be paying out of my own pocket. |
29th Apr 2013 11:08am |
A 4.4 can do that?? I have seen people hitting 22mpg on here with their SC but that is 60mph most of the way FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
29th Apr 2013 11:12am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
That was my reason for going from an SC to a TDV8 Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
29th Apr 2013 11:35am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I'm pretty new at FFRR ownership, but the only car I've ever had that 'left me stranded' was my very reliable, well maintained HONDA ACCORD. (The clutch just went leaving me with a nicely purring engine and no way to get into any gear. I had it recovered to the nearest dealer and they had it back on the road the next day.)
30th Apr 2013 1:04am |
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 |
Good luck on your search.if you read the various posts on here you will know what to look out for when buying your FFRR.Reliability wise its never left me stranded because it normally warns you when something is not right before-hand.Here`s my views for what its worth.had mine 9 months now,pre-facelift V8 05` plate 105k miles,12k purchase price.Just had new compressor and front air struts-cost £1000.Apart from that nothing else really.Had all the suspension struts checked pre-purchase and all were ok then.Just one of those things really.Mileage-16mpg round town.20mpg motorway.I don't do many miles so not a problem.If you're going to put miles on it then if you can stretch to TDV8,you have the best of both worlds,power and more mpg.It really is a fantastic car and you should take the plunge or you might regret it.For me it has a presence that no other car I have owned has got.What`s the worst that can happen? If you find you have maintenance or reliability issues that you can`t put up with then sell it on.Like any second hand car with miles on it,it`s the luck of the draw. 05`V8 AUTOBIOGRAPHY |
30th Apr 2013 8:39am |
mark_j Member Since: 11 Dec 2012 Location: somerset Posts: 78 |
Was in same boat, got a Jag XJ with the superb AJV8 motor and that will return 30 on the motorway and sounds amazing but i could not live with the MPG of that motor in a FFRR, for the same mpg as the TD6 i would say the TDV8 is worth the stretch the main bonus being much more power without the gearbox worries, there is a very keenly priced TDV8 on the for sale section. |
30th Apr 2013 8:52am |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Well it's very dependant on the vehicle you buy. Read the posts on here about, "what to look out for" and "buying advice" get to know the vehicle before you purchase it. Take it out for more than one test drive.
1st May 2013 2:44pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I have had my TDV8 for 18 Months, only been left stranded once and that was my fault. Spent all day cleaning it inside and out, doors opening an closing all the time and I ended up with a flat battery.
1st May 2013 5:16pm |
Thanks for the info guys. I've been reading all the buying guides on here and the wiki. I feel well armed now to start looking at a few. |
2nd May 2013 6:51am |
