Home > Off Topic > Fridge freezer acting up
Gents,
My AEG fridge freezer has just started to Censored up. The fridge side works fine but the freezer has started to warm up. I cant see anything obvious but looks can be deceiving. Should both compressors be hot/warm? Any help would be great as don't really want to be spending loads on a new unit. How much do engineers cost to look at the Censored thing? Can i run the fridge with a knackered freezer? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #185213 27th Apr 2013 10:23pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Sounds like the FSR has failed Laughing
Post #185218 27th Apr 2013 11:51pm
At first I thought it needed a new battery. Rolling with laughter [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #185230 28th Apr 2013 7:29am
Is it definitely split into 2 systems?
If so then it could be just a case of either the gas leaking out or the pump failing. There are some simple electronics in it which can be tested by using the temp control and forcing it to maximum or super freeze some call it, that should make it run almost all the time to cool the unit.
Engineer prices vary but you will likely have a call out charge and then labour charge then parts charge Sad
Have you googled the model number at all?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185243 28th Apr 2013 9:09am
Yep googled and not really revealed anything. I think it's 2 systems as it has to black bballs at the back. Assuming one is the compressor for the freezer and the other compressor for the fridge. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #185251 28th Apr 2013 10:21am
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
What I would do:
Suspect thermostat or compressor PTC.
Switch off for 1/2 hour. Set thermostat to coldest setting. Monitor the compressor motor voltage (if you are confident with that). Switch on. Is there power to the motor?
If no power to motor then electrical fault - I have had both thermostat and PTC fauls (refer to youtube).
If power to the motor and no start could be starter Cap but if not then this is going to need a 'fridge person.
Post #185252 28th Apr 2013 10:42am
Sit Rep: freezer defrosted and fired back up. Compressor is running and cooling. Started at +20C and was falling quite quickly when I left to come out. Will see what's happened when I get home. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #185275 28th Apr 2013 2:15pm
Fingers crossed Rob Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185299 28th Apr 2013 4:09pm
Temps down to -7C! Fingers crossed. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #185347 28th Apr 2013 8:56pm
Sit Rep: Freezer Dead! Big Cry Repair guy rehashed and pretty much came straight out! Not happy. A good quality AEG unit just over 6years old has just been turned into a glorified beer fridge! Evil or Very Mad [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #185785 30th Apr 2013 3:22pm
duckworthparts
Site Sponsor
nothing wrong with a glorified beer fridge Whistle You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #185787 30th Apr 2013 3:55pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
^ +1 Thumbs Up Thumbs Up Thumbs Up Mine was a blue one! Smile
Post #185788 30th Apr 2013 4:04pm
trust you to think of that Dan... Laughing ... - .- -.
Post #185792 30th Apr 2013 4:19pm
Yeah just drill 2 holes from the fridge into the freezer about 50mm in size maybe 100mm one near the side, one in the centre and then you have even more beer storage space or white wine if you like that kind of plonk Smile
Or for me it would just be full of deserts Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185802 30th Apr 2013 4:49pm
