Home > Technical (L322) > Off road height |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1696 |
the light should be on next to off road as that's what the car is in. You need to check that all doors and boot are closed properly or the car will not drop and the rotary switch will not do anything (although I think it should at least flash??) Ash
27th Apr 2013 3:09pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16257 |
Try turning the car off and on again and retry with the doors closed... |
27th Apr 2013 3:23pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
I just took the car out and went over 30 and it righted itself...
27th Apr 2013 3:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35198 |
i should think it hasnt been in the off road height for a while so it could have stuck up there.. ... - .- -.
27th Apr 2013 4:00pm |
Just drove the car 200 miles and lowered the car to access height and the old problem has arisen again.
5th May 2013 10:28am |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 |
You may want to read my previous thread on EAS "issues"
5th May 2013 11:48am |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 417 |
O2 sensor and suspension completely separate, no way connected.
5th May 2013 12:08pm |
I agree about dealers being part swappers.
5th May 2013 4:09pm |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 |
When the air pump overheats that throws up the error message that you are getting and no lights on.
6th May 2013 3:52pm |
Bill, how do I get the pump ventilated? 2009 Vogue TDV8 Nara Bronze
6th May 2013 7:50pm |
Soz for delay, work got in the way.
7th May 2013 3:10am |
Bill thanks. I wonder whether it overheated due to the car being loaded up.
7th May 2013 8:14am |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
It's sometimes an indication of a pinhole in the airbag causing it to leak very slowly, but enough for the compressor to run overtime?
7th May 2013 11:09am |
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 |
Ditto Allseeingpie.Had similar problem myself.You need to check air-struts for leaks.Have you had any sagging on any 4 corners? If there`s a leak on any of them it will overwork the compressor, which then shuts down.Had mine done at an Indie and I think they sprayed water on all 4 -just like checking for a puncture.End result was new compressor (because I left it too long to diagnose problem,therefore knackering the compressor) and 2 x new front bags (gutted) total cost fitted £1000+.EAS problems seem fairly common with the FFRR and IMHO the less you play around with it the better. 05`V8 AUTOBIOGRAPHY |
7th May 2013 4:22pm |
