Fitting - as far as I can remember is
Disconnect Battery - v v important or so Im told
Remove side vents , trim under lower glove box and then glove box
Wire loom in between radio unit (under glove box) and ipod unit (v small box)
Drill access hole in very rear of glovebox and affix ipod jacks (there is a switch to choose CD changer or IPOD)
fit everything back again
connect battery - worked first time no probs.
The sound is great but its still a bit disappointing in terms of control only get to see five playlists but you do get full touchscreen control, phone muting etc etc. I had an aftermarket add on for my BMW 5er which was truly amazing and gave full and total control over the ipod and everythng that's on it!
Howver, if you like your music - I really recommend it. Soem of the fitting bits (like drilling an access hole is not vital to the operation fo the ipod - just makes it look better....
