Home > Technical (L322) > Rear Washer not washing!
Brightondefender
As per the title my rear washer is not spraying out onto the window - the wiper works fine. Am I missing something stupid here like a separate bottle for the rear? Bit worried that a pipe may be disconnected and Censored out water into a place it's not meant to be going...... FTR the front washers and headlight washers all work great.
Any suggestions at all....
Many thanks
Post #181135 3rd Apr 2013 9:23pm
daveo
just done this, very easy...start by taking of the cover inside the tail gate,it covers the wiper motor.. you will see the water feed connecting to the wiper motor, in that short length of black pipe there will be a small one way filter. check there first, disconnect and see if you are getting water upto the filter, run it for a while to clear the line,clean or replace the filter, remove the pipe from the base or the wiper to make sure you are now getting water to wiper, if you are but still not out if the wiper arm you will have to go to the next step...
you need to clear out the wiper arm cap but you can not remove it unless you remove the tailgate spoiler, 3 bolts from in side the tail gate and it slides forward and unclips, put a towl across the roof and move it back.
you now can remove the wiper arm, test it and with the cap removed you should get a jet of water shooting out, if not then get a long thin wire and push it down the center hole to clear and test, if all is good then clean and replace the cap. job done Thumbs Up
if you find that you cant clear the center shaft you will have to remove the wiper and then the motor and clear it
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #181136 3rd Apr 2013 9:46pm
Andy
Mine isn't spraying water - I can hear the motor run when I push on the stalk, but it doesn't run continuously. More an intermittent sound of the motor running. Front works fine though.
Post #181149 4th Apr 2013 6:17am
dirtyharry
I've just done the "clean-out" process described by daveo above and found the wiper arm feed blocked with crap. After cleaning it out I put a bucket under the pipe and tested the water flow before putting it all back together, but even now, it takes a while for the water to eventually come through. But at least it works! Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #181170 4th Apr 2013 7:54am
daveo
noddy, the rear washer does not run all the time, whn you push the stalk the wiper starts ans you will get 3 bursts of the water pump about a second apart. follow step 1 and disconnect at the filter ti see if you get a flow of water,if not you neen to back to the washer bottle.. V8 facelift Range Rover Autobiography 22" wheels.
Post #181190 4th Apr 2013 9:29am
daveo
check the one way valve, thats put there to stop the water drainig back and doing what you discribe, you should only be able to suck or blow one way, there is a direction of flow on the filter V8 facelift Range Rover Autobiography 22" wheels.
Post #181191 4th Apr 2013 9:34am
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I've been through this process too.
Had the motor noise but no water.
Having taken everything to pieces and cleared out all the pipes etc, I had water flowing through the pump to the wiper, but still none was making it on to the rear windscreen.
Turned out that I just needed a long thin sewing needle held in a pair of pliers to clean out the jet nozzles. Whistle Embarassed
You're probably not as stupid as me and have checked that first....but thought I'd share my stupidity just in case it helps someone! Rolling Eyes Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #181208 4th Apr 2013 11:44am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I replaced the non return valve but it still takes a few wipes of the wiper before any fluid reaches the rear window. After i've used it a couple of times it's then instant..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #181389 5th Apr 2013 7:14am
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Where can I get a 1 way valve?
Post #183604 18th Apr 2013 8:39pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
I carefully removed the black plastic cap which houses the washer jets.
I then cleaned out the jets with a needle as described above. If you carefully select the needle size you can push it through the jet and can see it on the inside of the plastic housing, I did this along with checking the flow through the one-way valve and now all is well.
I think the idea of the three timed bursts is to disperse the water across more of the rear screen.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #183605 18th Apr 2013 9:00pm
super8
2005 Range Rover Supercharged 4.2 SC V8 Java Black
One Way Valve
This is a guess around the one way valve... but I reckon you will be able to get something that is comparable to anything that a dealer would give you from an aquatics store... or a quick search on ebay reveals a lot....
http://www.ebay.co.uk/sch/i.html?_nkw=one+way+valves Range Rover - Supercharged - On the drive.
Discovery V8 - Sadly gone.
Post #183612 18th Apr 2013 9:44pm
TtheArab
2003 Range Rover HSE 4.4 V8 Giverny Green
Same issue. Jets in wiper arm clogged and rusted so I bought new arm and did clean out. All working now. Be careful when you take wiper arm off as small plastic piece that goes from water feed to wiper arm pings off and disappears into the great hole all small things go to.
FWIW I have a spare new wiper arm in garage as accidentally ordered 2 when 1st transaction seemed to have failed !!! PM me if anybody wants it.
Post #185400 29th Apr 2013 8:27am
daveo
PM sent Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #185536 29th Apr 2013 4:40pm
