Home > Technical (L322) > Air suspension compressor - replace or repair?
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Classic fault message "air suspension inactive"...still need to diagnose this as it only happened this morning when I went to lower the car for my mother to get in but I'm assuming the worst.
If this ends up being a compressor fault is it best to replace the entire compressor unit or to carry out the repair to the pistons?
I'm not surprised this has occurred as the suspension was quite slow the last couple of times it was lowered.
Post #180609 31st Mar 2013 7:17pm
Andy
Repair it mate - much cheaper. Contact Meerbusch for a kit.
Post #180933 2nd Apr 2013 5:08pm
Rich86
Noddy is this quite an easy repair?
Post #180935 2nd Apr 2013 5:23pm
wiki. Thumbs Up ... - .- -.
Post #180938 2nd Apr 2013 6:14pm
Andy
Yes. If you're fairly competent with spanners, its a doddle.
Post #180939 2nd Apr 2013 6:14pm
muffster
2002 Range Rover Vogue Td6 Java Black
Hello mate,
For what it's worth I tried a cheap kit from eBay, as others on here have done but it did not work. It's now In the garage having a new compressor fitted.
Worth a stab at £35 but may not sort it out for you.
Post #181443 5th Apr 2013 2:19pm
ebajema
Go for the Meerbush kit is my recommendation. MY 2010 5.0 SC Galway green and sand interior!!
Post #181460 5th Apr 2013 4:27pm
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Got the kit from Meerbusch, now working like it should. Get the kit from him before he gets sold out.
The bore of the old cylinder head was to big, in my case changing the head was needed. Changing only the piston ring wont get you far.
Post #181464 5th Apr 2013 4:37pm
Rich86
Where did you get the Meerbusch kit from?
Post #181689 7th Apr 2013 1:25pm
L322RR
directly from him, drop him a PM
Post #181691 7th Apr 2013 1:29pm
dnbaker
United States 2004 Range Rover Westminster 4.4 V8 Bonatti Grey
I just installed Meerbusch's repair kit yesterday. It's a very nice kit and only took me about 30 minutes - most of which was just taking everything apart to get to the compressor. My system works much better now. For the money, I would definitely try this repair first before investing in a new compressor. 2004 RR Westminster 4.4 V8
Bonatti Grey/Jet
Post #181695 7th Apr 2013 1:53pm
