![]() | Home > Maintenance & Mods (L322) > Body Control Module |
daveym Member Since: 21 Aug 2011 Location: place Posts: 62 ![]() ![]() |
Daveo,
Found my old post
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
the reason is as in my other post about my rain sensor not working, its all there sensor but not sure if it was added after and the bcm does not support the rain sensor option. V8 facelift Range Rover Autobiography 22" wheels.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
hi dave, not sure why you are having problems with the rain sensor but all range rovers expect HSE or SE i think had the rain sensor fitted as standard so your original BCM unit would have had it activated from the factory. Its an option that you can turn on and off using a fault mate etc..
not sure whats going on, yes being an autobiography you would think it would be there but i cant get it to work, waiting to here from gap idtool as no option comes up in there menu, V8 facelift Range Rover Autobiography 22" wheels.
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
seems dead easy to change the bcm on a ff l322 daveym , as goes for a p38 swap its a lot more of a job |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
hi dave
