Home > Maintenance & Mods (L322) > Body Control Module
daveo
Body Control Module
Hi, has any one changed the BCM on a pre touch screen with a second hand one, ie straight swap or does it need to be coded before it is used. V8 facelift Range Rover Autobiography 22" wheels.
Post #180523 30th Mar 2013 10:45pm
daveym
United Arab Emirates
Daveo,
I did the swap in my 2003 Vogue. Simple job - unhook the battery, locate BCM under passenger seat ( I found it easier taking the seat out - four bolts only) and swap over, put battery back on. Job done.
It took around 20mins.
Forgot to mention there is something about the mileage - it's in Rave I think. Something about putting in a BCM from a higher mileage car and then it registering this mileage on the dash and then it sticks. But it doesn't work the other way.
Post #180525 30th Mar 2013 11:18pm
daveym
Found my old post
http://www.fullfatrr.com/forum/post134850.html#134850
I wish I had done pictures now.
Post #180526 30th Mar 2013 11:33pm
daveo
the reason is as in my other post about my rain sensor not working, its all there sensor but not sure if it was added after and the bcm does not support the rain sensor option. V8 facelift Range Rover Autobiography 22" wheels.
Post #180528 31st Mar 2013 12:49am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
hi dave, not sure why you are having problems with the rain sensor but all range rovers expect HSE or SE i think had the rain sensor fitted as standard so your original BCM unit would have had it activated from the factory. Its an option that you can turn on and off using a fault mate etc..
Matt
Post #180575 31st Mar 2013 12:52pm
daveo
not sure whats going on, yes being an autobiography you would think it would be there but i cant get it to work, waiting to here from gap idtool as no option comes up in there menu, V8 facelift Range Rover Autobiography 22" wheels.
Post #180581 31st Mar 2013 3:15pm
klf400
seems dead easy to change the bcm on a ff l322 daveym , as goes for a p38 swap its a lot more of a job Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #180678 1st Apr 2013 11:25am
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
hi dave
i have a autobiography as well and dont have the rain senor either
Post #181414 5th Apr 2013 11:15am
