![]() | Home > General (L405) > Terrain Response 2: £100? |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
No auto response mode ? Far to many gone... |
Mizengeo Member Since: 08 Mar 2013 Location: Reading Posts: 47 ![]() ![]() |
The vogue has terrain response and you can upgrade to get it to select the right program automatically. SE and ATB have as standard. I don't go off road that much and when I do it is it pretty simple stuff so figuring out which program to use shouldn't be a problem - always managed ok in my Discovery. £100 is nothing in the context of the overall price but I didn't specify because it seems to me it is the sort of thing that could wrong and prove a real pain. Geoff |
campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729 ![]() ![]() |
^^ case solved thanks |
Be interesting in 5 years time, I will have to check if its got Auto TR when buying in.... |
wonder if dial is just the same, or like the last L322s?
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
The difference is if you have the full on TR2 it has a marking "Auto" and an orange light on the top of the selector, otherwise the selector doesn't have the Auto marking or the light.
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
Well said Tim!!
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
I thought the HSE could get the low box for £400 (off road pack). It didn't look like the SE could be spec'd with it.
If it's £100 I bet a few minutes with an msv2 would enable it despite the lack of physical switch |
