Home > Technical (L322) > RSW All Comms
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
RSW All Comms
I am thinking of getting one of these, it seems to be good value considering the USD exchange rate and the list of functions it has.............anyone had experience of one and how quick or reliable the delivey is from the good old US of A...........
Post #179705 25th Mar 2013 9:16pm
They are good and cheap, BUT 1)you need a laptop to use it so if you get a fault away from home your a bit screwed unless you keep a laptop in the car, 2) the support isn't the best so your kind of on your own I you have a fault. I've had one and it was good but if I had the choice again I would have had a IID tool. Much better in the long run! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #179707 25th Mar 2013 9:36pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Gentlemen, I can recommend the RSW, if you are working at different Range Rovers like I do, but for private use the Tool from GAP SteveMfr is the best. A client of me brought his GAP tool to me, and shows me all functions, top!!! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #179723 26th Mar 2013 7:40am
ebajema
Go for the IID tool from Steve, their support is excellent. I use the Faultmate and it is great but very expensive. MY 2010 5.0 SC Galway green and sand interior!!
Post #179724 26th Mar 2013 8:07am
jaybear
France
Netsonic Steve
just be aware that you need all your pixels to work fully to use the GAPP Tool . which may be an issue for a 2002 vehicle .................... Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #179734 26th Mar 2013 10:17am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I've got the RSW kit and I have to say it's done me proud. Works fine for everything I've needed to do - also worth getting the Navcoder kit - that covers the bits the RSW doesn't!
Post #179736 26th Mar 2013 10:26am
I find the All Comms unit excellent for straight forward diagnostic and fault clearance functions. The only drawback is the fact it can't deal with the TD6 engine.
Post #179737 26th Mar 2013 10:28am
Simes
It's American - and they only use Diesel engines in sludge pumps...
Whistle
Post #179739 26th Mar 2013 10:43am
Reformed
BMW edibas DIS software works with the early diesel engine to! I used it during my ownership. Thumbs Up Reformed
Post #179771 26th Mar 2013 5:18pm
netsonic Steve
Thanks for all the feedback, my pixels ar not perfect so the RSW may be the best option...........i will do a bit more homework on the options as its a big investment
Post #179847 26th Mar 2013 11:30pm
Andy
As stated above, the support isn't great. I've emailed Storey several times and he doesn't seem to be interested. His last email said he'd got other things going on in his life and hadn't put much into the Allcomms. Says it all to me
Post #180313 29th Mar 2013 5:17pm
daveo
it is a shame, what was a very simple and easy to use tool seems to have bitten the dust, i wish he could take a bit of time and add the lcm commands to it... V8 facelift Range Rover Autobiography 22" wheels.
Post #180319 29th Mar 2013 5:33pm
i think the chinese copies might have taken a toll on his enthusiusm .. ... - .- -.
Post #180325 29th Mar 2013 6:26pm
