Home > Technical (L322) > RSW All Comms |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
They are good and cheap, BUT 1)you need a laptop to use it so if you get a fault away from home your a bit screwed unless you keep a laptop in the car, 2) the support isn't the best so your kind of on your own I you have a fault. I've had one and it was good but if I had the choice again I would have had a IID tool. Much better in the long run! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
25th Mar 2013 9:36pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Gentlemen, I can recommend the RSW, if you are working at different Range Rovers like I do, but for private use the Tool from GAP SteveMfr is the best. A client of me brought his GAP tool to me, and shows me all functions, top!!! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
26th Mar 2013 7:40am |
Go for the IID tool from Steve, their support is excellent. I use the Faultmate and it is great but very expensive. MY 2010 5.0 SC Galway green and sand interior!!
26th Mar 2013 8:07am |
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 |
Netsonic Steve
26th Mar 2013 10:17am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I've got the RSW kit and I have to say it's done me proud. Works fine for everything I've needed to do - also worth getting the Navcoder kit - that covers the bits the RSW doesn't! |
26th Mar 2013 10:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
I find the All Comms unit excellent for straight forward diagnostic and fault clearance functions. The only drawback is the fact it can't deal with the TD6 engine. |
26th Mar 2013 10:28am |
It's American - and they only use Diesel engines in sludge pumps...
26th Mar 2013 10:43am |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
BMW edibas DIS software works with the early diesel engine to! I used it during my ownership. Reformed |
26th Mar 2013 5:18pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
Thanks for all the feedback, my pixels ar not perfect so the RSW may be the best option...........i will do a bit more homework on the options as its a big investment |
26th Mar 2013 11:30pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
As stated above, the support isn't great. I've emailed Storey several times and he doesn't seem to be interested. His last email said he'd got other things going on in his life and hadn't put much into the Allcomms. Says it all to me |
29th Mar 2013 5:17pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
it is a shame, what was a very simple and easy to use tool seems to have bitten the dust, i wish he could take a bit of time and add the lcm commands to it... V8 facelift Range Rover Autobiography 22" wheels.
29th Mar 2013 5:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
i think the chinese copies might have taken a toll on his enthusiusm .. ... - .- -.
29th Mar 2013 6:26pm |
