![]() | Home > Maintenance & Mods (L322) > Non Land Rover brake discs |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
King can you post the link for the eBay ones or let m know where you bought them please so that I can take a look... |
I had the drilled and grooved one from Britpart (I think) good discs and worked well. Bought them for their anti corrosion coating to prevent the rears looking awful due to corrosion on the lip. They worked very well and looked more substantial. Downside was under heavy braking say (70>10 on a motorway slip road) you could hear a quite loud fluttering as the slots wizzed by the pad. Sounded like a warped disc but no vibration. Just my 2p worth. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 ![]() ![]() |
Is that fitted?? Thought Td6 dics were about £60 a piece genuine and pads about £50 an axle set genuine. Would've thought petrol be similar?? |
No that's just to supply them. If you break it down the discs are £73 front £63 rear, pads front £62 rear £72 and the sensors are front £14 rear £12. When you add this up and add VAT...like I said if genuine parts could be sourced cheaper than I'd like to know. |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
I got these and fitted them with no problem couple of weeks ago. Rear disks, pads and sensor for £70 plus £8 postage
What did you pay for the fitting? |
Did it myself and since it's such a pleasurable experience I don't charge for my time |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
i to brought both front and rear discs/pads of ebay at around £70 fronts and £80 rears...they came with mintex pads...
The cheaper the disc the quicker they rust... |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Land Rover don't make discs or pads... |
I put Brembo discs on my Td6. Try www. performancebrakesonline.
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
all depends on age of vehicle etc, early front discs rrp £100+vat Rich, you got forum discount applied ![]() Please supply your full name address when sending a paypal payment. https://www.facebook.com/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: robin.hall@duckworth.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models ![]() |
Well the hub part is the most annoying rust part and that can easily be painted.
Dan, discount appreciated but still coming in at quite a bit. What is the discount exactly! Is it free postage? Just looked at thee bay link above and they only supply one wear indicator per pair of pads and disc. Aren't the wear indicators fitted on each hub? |
