Home > Maintenance & Mods (L322) > Non Land Rover brake discs |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
King can you post the link for the eBay ones or let m know where you bought them please so that I can take a look... |
18th Mar 2013 6:34am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I had the drilled and grooved one from Britpart (I think) good discs and worked well. Bought them for their anti corrosion coating to prevent the rears looking awful due to corrosion on the lip. They worked very well and looked more substantial. Downside was under heavy braking say (70>10 on a motorway slip road) you could hear a quite loud fluttering as the slots wizzed by the pad. Sounded like a warped disc but no vibration. Just my 2p worth. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
18th Mar 2013 7:49am |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 |
Is that fitted?? Thought Td6 dics were about £60 a piece genuine and pads about £50 an axle set genuine. Would've thought petrol be similar?? |
18th Mar 2013 8:41pm |
No that's just to supply them. If you break it down the discs are £73 front £63 rear, pads front £62 rear £72 and the sensors are front £14 rear £12. When you add this up and add VAT...like I said if genuine parts could be sourced cheaper than I'd like to know. |
19th Mar 2013 6:42am |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
I got these and fitted them with no problem couple of weeks ago. Rear disks, pads and sensor for £70 plus £8 postage
19th Mar 2013 8:26am |
What did you pay for the fitting? |
19th Mar 2013 8:30am |
Did it myself and since it's such a pleasurable experience I don't charge for my time 2007 TDV8 Vogue SE Java Black |
19th Mar 2013 8:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
i to brought both front and rear discs/pads of ebay at around £70 fronts and £80 rears...they came with mintex pads...
19th Mar 2013 9:00am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
The cheaper the disc the quicker they rust... |
19th Mar 2013 9:16am |
Land Rover don't make discs or pads... |
19th Mar 2013 9:42am |
I put Brembo discs on my Td6. Try www. performancebrakesonline.
19th Mar 2013 12:28pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
all depends on age of vehicle etc, early front discs rrp £100+vat Rich, you got forum discount applied You can paypal direct using - www.paypal.me/duckworthparts Please supply your full name address when sending a paypal payment. https://www.facebook.com/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: robin.hall@duckworth.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models |
19th Mar 2013 12:35pm |
Well the hub part is the most annoying rust part and that can easily be painted.
19th Mar 2013 3:23pm |
Dan, discount appreciated but still coming in at quite a bit. What is the discount exactly! Is it free postage? Just looked at thee bay link above and they only supply one wear indicator per pair of pads and disc. Aren't the wear indicators fitted on each hub? |
19th Mar 2013 3:52pm |
