![]() | Home > Technical (L322) > Sudden Dramatic Water Loss - 4.2 SC |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
As per the title really.
Hi mate, stop driving the car immediately. It could be the same issue that I am having, the dreaded leaking oil cooler. I hope not but have a good look !!!
Have read your thread.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
It'll be the radiator, I had to change mine - what year is yours ? There was a TSB for the radiator on 06 MY cars - they modified the radiator to rectify the known issue. It leaks on the rhs just where the core meets the side tank - if you grab a torch you should be able to see it. A new rad from Dan was about £200 from memory Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Good news:
I believe JustinP had the same issue about a year ago, search his posts....at least you know what it is ! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Well that is much better than the trans cooler mate, not great but at least this should be relatively easy to do. New hose and clamps won't cost the world and hopefully the indy won't take too much time. You may need new gaskets as well but still not the world. MY 2010 5.0 SC Galway green and sand interior!!
Alexdyer Member Since: 11 Feb 2012 Location: Bluebell hill village Posts: 24 ![]() |
this really isnt such a bad job to do!
Glad to hear it is resolved. I am still waiting for my cars cooling system to be cleaned. They are still flushing all the oil and muck out after the transmission cooler failure.
Where the hell were you 11 days ago?
When you open the bonnet, it looks a bit daunting in there the first few times |
After you have taken the engine cover and intake section off everything looks a little easier!
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
I did, it was a supercharger off job to route the hose, thankfully mine was covered by the LR waranty, otherwise it would have been expensive. I believe LR modified the thermostat and hose from 2007 so the pipe can be removed without removing the supercharger. Good luck and let us know what it cost to repair. ![]() Gone - Range Rover Supercharged 2006 ![]() |
