Home > My Range Rover > Gearbox gone again
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
Gearbox gone again
Luckily the warrantee is still valid so it's off to the garage on Monday morning Big Cry
Post #175465 2nd Mar 2013 9:18pm
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
Good luck with the repair this time. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #175466 2nd Mar 2013 9:19pm
cleughy
The damn thing is working normally again, I've had the errors cleared to see if it happens again, I may have a full leak under the bonnet so that's one to get checked out next..... Shocked
Post #175828 4th Mar 2013 6:10pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
My service history shows that my car has had 3 boxes in 30K miles. The last box I had lasted 13K miles (just out of warranty Big Cry ) .
I'm hoping as the cars get older the cost of replacing the gearbox will come down, as £2K every year or so is to much...
Post #175831 4th Mar 2013 6:27pm
cleughy
It turns out that it was a faulty sensor so the work as done under warrantee Very Happy
Post #186576 4th May 2013 7:54pm
cleughy
well it went t!ts up again, so i have had it back in and the clutch had burnt, so thats been replaced under the warantee, the guys there said its only the 2nd time they had seen one go this quick after a rebuild, so it makes me wonder if they put a new one in when they did it Thumbs Up
just in time for taking the caravan down to cornwall next week. Very Happy
Post #188480 15th May 2013 4:18pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
They must clean out the cooler and pipes, otherwise it will keep failing.
Ashcrofts do a product called Dr Tranny (an automotive cleaning product, not a strange porn film). http://www.ashcroft-transmissions.co.uk/in...ductId=181
When the box comes out, just connect to the pipes and let it clean through. 10MY TdV8 Ipanema Sand
Post #196119 25th Jun 2013 4:37pm
Mine's done nearly 50k since a rebuild (done by the previous owner). No probs yet (famous last words) despite lots of towing.
Post #196135 25th Jun 2013 6:05pm
Richcl
Third time my gearbox has let me down in 20 months now (33K milage) It's not funny anymore (£4K in repairs and servicing) Big Cry
I'll be taking my car elsewhere to be fixed, I know the GM box has it's faults but have lost confidence in the garage I use, if (when) it fails, if it's out of warranty I'll find another garage.
On that note anyone had a good experiance with the repair of the GM box, could recommend a garage? Cause it's only a matter of time until this fails again...
Post #198365 10th Jul 2013 4:59pm
Mustard
Im in your neck of the woods and im interested in who you have used for the work ?
I been deliberating over getting the gearbox oil changed for a short while and have made arrangements for it to be done in the next few weeks at a 4x4 specialists. Im terrified of the gearbox failing and am interested in knowing where to go and how much it will be costing me if / when the inevitable happens Rolling Eyes
Post #198399 10th Jul 2013 10:05pm
Google A1 Premier Transmissions Thumbs Up
Post #198414 11th Jul 2013 8:19am
I've got to say - this seems like poor refurbishment work. Everyone knows the GM box is a weak point but they don't break every 12000 miles or anything like that.
Post #198419 11th Jul 2013 8:49am
The only way to really resolve these issues is to replace the worn clutchs and TC and use the upgraded sonnax valve block.
I'd also reccomend the ECU upgrade offered by a german company i believe. It will help reduce stress on the clutches and TC by allowing earlier lockup and less slipping.
Just my tuppenth and its not a cheap job even if done DIY but when your spending £2k its gotta be worth it surely. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #198443 11th Jul 2013 10:57am
Mustard
Thanks for the heads up, Ive logged that firm in my phone Very Happy I would ideally prefer using someone closer to home just in-case of any snags after the job was done., but if long distance is the better option then so be it.
There's a wealth of info spread all over this forum about this gear box and its issues, its been very informative for me and im sure others the same, it would be a great idea if it could be consolidated for reference like some of the articles in the wiki Thumbs Up
Post #198505 11th Jul 2013 9:07pm
cleughy
Address:
Robbs Garage
Claremount Road
Wallasey
Merseyside
CH44 2BW
Tel: 0151 638 1384
Email: robbsgarage@btconnect.com
Post #198565 12th Jul 2013 11:41am
