Home > Technical (L322) > Dipped head light flickers
RREIRE
Ireland 2007 Range Rover Vogue SE TDV8 Java Black
I have just bought my ffrr vogue. I will post pictures later in the week. I was out driving it and noticed the drivers dipped head light was not working. If I turn the lights off.It would come back on. It would start to flicker a few times and then go out. and I would get a message saying that my bulb had failed. It is a preface lift 05 model. I am getting a new diff on Monday for it. It was not changed in the recall. When I get it back I will post some pictures up.
Post #13450 20th Feb 2010 8:51pm
M44K TS
Mine does exactly the same from time to time, drivers side too. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #13451 20th Feb 2010 8:59pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Welcome. I had the same thing on another car. New xenon unfortunatley.
£250 plus from stealer.
On another note how do I find out if the diff has been changed on my 54 plate? 15MY SDV8 Vogue SE
Post #13452 20th Feb 2010 8:59pm
M44K TS
Something to do with the coupling I think?
Old one has splines, new one has a U/J?
I could be talking utter Censored though, I need to check to see if mine was done. 2006 Mercedes CLS
Post #13453 20th Feb 2010 9:00pm
RREIRE
Jem0911 wrote:
Welcome. I had the same thing on another car. New xenon unfortunately.
I gave my local dealer a call. I gave him my chassis number. He told me it had not been done.
Post #13455 20th Feb 2010 9:17pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Probably the ballast if the bulb is still working. If you change the bulbs, you might want to change them both as Xenon lights change colour temperature with age (they become more blue). The newer bulb will look much whiter by comparison.
I'd go for a replacement ballast, or at leat look at the connections first. Be careful though, Xenon ballasts operate at thousands of volts to ignite the gas in the bulb! Be warned.
Post #13490 21st Feb 2010 11:05am
RREIRE
Thanks Jayzee I will try that first. I will let you know if it works.
Post #13531 21st Feb 2010 10:48pm
jayzee
Good luck, hope it is something simple, but please take care with the voltage.
Post #13536 22nd Feb 2010 12:14am
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
hi I had this on my 05 so i swapped the bulb from passenger to driver side and found my bulb was breaking down so replaced both bulbs and now perfect rgds simon
Post #13631 22nd Feb 2010 9:03pm
RREIRE
Thanks for that. Can I fit bigger voltage bulbs? 4300 is standard. I was looking at 6000watts I think it is watts or volts? Do I have to disconnect the battery first? Or just make sure the light switch is OFF.
Post #13644 22nd Feb 2010 10:53pm
M44K TS
It's kelvins you mean, it's basically the colour temperature. 4300k is usually OE spec, I have 6000k in my Vivaro work van, they're alright but I prefer 4300k As far as I know, they are DS2 HID bulbs, so any aftermarket ones should work and will probably be cheaper than dealer prices.
Also, if you're poking about near the headlights, I'd disconnect the battery, the ballast can fire up to 25kv to the bulb which I dare say would give you a bit of a tingle 2006 Mercedes CLS
Post #13658 23rd Feb 2010 9:12am
jayzee
No offense meant here, but if you are asking these questions, I would suggest you take the car to a garage, or get a mobile vehicle electrician to sort it for you.
If you poke around there with the battery connected, the voltage could kill you from the ballasts.
Post #13678 23rd Feb 2010 11:17am
simonmanx
bulbs
Hi again i have looked into getting brighter bulbs and found that the dif between 4300k and even 8000k is the colour and not how bright they make the road seem i was advised 4300k are the brightest bulbs
Post #13810 24th Feb 2010 7:56pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hey guys,
From what I know, (and please oh learned friends correct me if I'm off the mark)
The 'K' unit of colour temp is not necessarily to do with the brightness, it's Kelvin as in the absolute unit of temperature so it relates to the temperature you would heat a non specific substance to in order to achieve the colour (in the way that metal when heated gets red hot and eventually white hot)... In the same way that wavelengths increase throughout the visible spectrum from infra red up through ultra violet etc... hence the increase in 'blue tint' as colour temp increases.
As the colour temp increases further the light gets more and more blue/purplish until around 12000K they are basically for show cars only and have fairly rubbish light penetration (again back to increasing lambda (wavelength) values suffering more from free space loss...
Also if you have very purplish looking HID lights you look like you should be driving a corsa with a 4" exhaust...
IMVHO, 4500K-6000K is where it's at for overall usage, but just my £0.02
Hope this helps in some way. Thumbs Up
Post #13812 24th Feb 2010 8:13pm
Das Doc
Germany
And what a nice 2p it is!
I have something for you at my house sir Thumbs Up Audi RS4 to replace my "wonky" TDV8
Freelander 2 TD4 HSE Auto for the Mrs. (the best, most complete LR product to date)
Searching for a Gallardo E-gear for fun.
TDV8 Vogue GONE
TDV8 Vogue GONE
RRSport HSE GONE
DISCO 3 HSE GONE
Defender XS GONE
Defender Tdi GONE
DISCO 2 ES GONE
DISCO 1 Tdi GONE
German brother of "The Doc" as he's banned on all FFRR/Disco 3/RRS/FL2 for being a pain in the FL2 forum Rolling Eyes
Post #13824 24th Feb 2010 9:37pm
