Home > General > my new 4.4 question
onethumb
my new 4.4 question
Hi all, I've just left a deposit on a 2004 FFRR 4.4 vogue. My first FF actually my first Land Rover. Very Happy
It drove lovely and changed gear with no issues. however the sat nav didn't work and will be replaced by the dealer, the indicator lights on the dash did not show nor did the light or fog lights symbol, although all these lights work. I've been assured all these issues will be fixed, however I have a concern over a small pile of grease that was on the heat shield next to the front prop and diff.
Should I be concerned?
Its due a service, which I've been assured will also be done.
This is a none franchised dealer.
Thanks for all your time.
Steve
Post #172708 16th Feb 2013 4:44pm
RR2008HSE
I'd run, and fast! Shocked
The dash should light up like a Xmas tree when the car is switched on. That shows you all the bulbs are working. There are symbols for both front and rear fog lights. If these are missing, what other warning lights are also being hidden?
The sat-nav. Many people replace them with later model BMW gear as they are showing their age. What's the dealer's plan? After market sat-navs will have limited functionality - loss of mpg and consumption reset and maybe other features.
You didn't mention service history. You want to know this.
If your still interested, definitely take it to a mechanic you trust that specializes in RRs and can interrogate the onboard computers. You don't want surprises. They are fantastic cars but are not known to be cheap and easy to fix.
Post #172764 16th Feb 2013 8:52pm
onethumb
Thanks for the reply, Its got service history up to this one.
Has any one got a picture of what the dash looks like when you turn the ignition on, so I can check it against the one ive just put a deposit on.
Thanks, Steve
Post #172769 16th Feb 2013 9:01pm
RR2008HSE
My ffrr is a US spec MY2008. I'll check it if you wish, but another 2004 owner would probably me of more help. Let me know. Thumbs Up
Post #172791 16th Feb 2013 11:51pm
Post #172795 17th Feb 2013 12:25am
This was exactly the same as mine when I got it. They need to pull fuse 47 I think it is and leave it out for about 5 mins. It makes the nav ecu stuff do a proper reset. Once back in everything worked as it should. Think it was due to a low battery. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #172812 17th Feb 2013 10:50am
steptoe
I had problems with the dash indicator lights (although indicators worked outside), screen and stereo not working on my 02 range rover.
I traced it to a faulty light control module in the drivers footwell. Thumbs Up
Post #172818 17th Feb 2013 11:19am
onethumb
Bloody brilliant, rob2529, 47p2 and Steptoe thank you all very much. Bow down
I'm supposed to be picking it up next week and was getting well concerned with all the horror stories about FF, but I also saw all the positive's and enjoyment that you all seem to enjoy.
Can't wait to get mine now. Any more info appreciated.
Post #172842 17th Feb 2013 3:11pm
They're a pain in the arse when they aren't going properly, but great when they are. The secret is to not let it know you are relying/depending on it to get you from A-B Big Cry Laughing Laughing
Post #172851 17th Feb 2013 4:36pm
