![]() | Home > General > my new 4.4 question |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I'd run, and fast! |
onethumb Member Since: 11 Feb 2013 Location: wolves Posts: 14 ![]() ![]() |
Thanks for the reply, Its got service history up to this one.
My ffrr is a US spec MY2008. I'll check it if you wish, but another 2004 owner would probably me of more help. Let me know. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
This was exactly the same as mine when I got it. They need to pull fuse 47 I think it is and leave it out for about 5 mins. It makes the nav ecu stuff do a proper reset. Once back in everything worked as it should. Think it was due to a low battery. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I had problems with the dash indicator lights (although indicators worked outside), screen and stereo not working on my 02 range rover.
Bloody brilliant, rob2529, 47p2 and Steptoe thank you all very much. |
They're a pain in the arse when they aren't going properly, but great when they are. The secret is to not let it know you are relying/depending on it to get you from A-B ![]() ![]() ![]() |
