![]() | Home > Maintenance & Mods (L322) > Loose pipe in rear of engine bay |
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 ![]() ![]() ![]() |
Anyone recognise this?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
do both screen washers work ok? ... - .- -.
Yep both front washers do, but the back doesn't........ Thought the pump was |
maybe that pipe runs to the rear washer, i'd try and follow it to see where it goes.. ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Looks too heavy to be a screen wash pipe |
If your mean the white one I think it's the gearbox breather. Mines the same. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Yep, mines the same, thers a few around that area, gear box and axle breathers I should imagine |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
mine is the same as well , the front diff breather vents under the inlet manifold you can see it going under the plastic cover on the right hand bank rocker cover , you somtimes get oil vapour discharge droping into the valley so i removed mine and relocated it on the inner wing under the power steering reservoir |
