Home > Maintenance & Mods (L322) > Loose pipe in rear of engine bay
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Anyone recognise this?
Sorry for the dirty engine bay, but while checking for a air leak, I found this SMALL WHITE pipe/hose at the rear of the engine.
Is it supposed to be loose?
Its lying horizontally so I don't think its a drip tube?
Thanks for any help
Hope this link works Shocked
 L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #171904 13th Feb 2013 2:11am
do both screen washers work ok? ... - .- -.
Post #171930 13th Feb 2013 9:59am
CBH25
Yep both front washers do, but the back doesn't........ Thought the pump was Censored . L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #171936 13th Feb 2013 10:21am
maybe that pipe runs to the rear washer, i'd try and follow it to see where it goes.. ... - .- -.
Post #171940 13th Feb 2013 10:27am
Looks too heavy to be a screen wash pipe
Post #171972 13th Feb 2013 12:17pm
If your mean the white one I think it's the gearbox breather. Mines the same. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #171981 13th Feb 2013 12:51pm
Deasy
Yep, mines the same, thers a few around that area, gear box and axle breathers I should imagine
Post #172081 13th Feb 2013 7:33pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Yes it looks like a breather, mine has one like that and it's just open ended Thumbs Up Range Rover 4.4 V8 Vogue
Post #172353 14th Feb 2013 7:25pm
klf400
mine is the same as well , the front diff breather vents under the inlet manifold you can see it going under the plastic cover on the right hand bank rocker cover , you somtimes get oil vapour discharge droping into the valley so i removed mine and relocated it on the inner wing under the power steering reservoir Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #172355 14th Feb 2013 7:34pm
