Home > Maintenance & Mods (L322) > Changing green interior LED's |
The hardest part will be getting LED's that are not to bright or to dim, which is a personal thing i guess. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
12th Feb 2013 11:24am |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
I think your right, trial and error to match what's already fitted. Modern LED's are always very bright even with a reduced voltage. It might be easier to change the resistance values of the dimming switch. Well iv found something to occupy myself today, the MOT on my other car expires tomorrow so off for a test I go |
12th Feb 2013 11:34am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
by green i gather you mean the yelowish ones ...i just changed the 2 overhead lights to smd's and that was enough... ... - .- -.
12th Feb 2013 11:39am |
No I'd actually leave the yellow ones (suspension/heated seats) I mean anything that lights up green inside once the external lights are turned on. That said do they already emit white but each switch has a green diffuser? |
12th Feb 2013 11:44am |
not sure , probably a diffuser like you've suggested.. ... - .- -.
12th Feb 2013 11:46am |
I'll plug a spare pcb in and investigate further. |
12th Feb 2013 11:56am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I think you'll find they are actually green LED's - not white ones with a diffuser
12th Feb 2013 12:33pm |
I think they are green too, that's perfect. I'll have a look on RAVE for schematics regarding that control module. In theory it should still be resistance dependent. I know a good electronics company that could identify the values of the green LEDs and offer a similar matched value. |
12th Feb 2013 1:31pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Someone on here did change all their dash leds to white when they had their pixels done. Do a search on "pixels", there were photos too .
12th Feb 2013 3:55pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
I have been thinking about this for quite a long time too, the dash is the easyest bit to do i think, but the touch screen will be the worst!
12th Feb 2013 4:42pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
this is what you are up against,
12th Feb 2013 7:08pm |
Barracuda my other car is a golf so that must be where it came from
13th Feb 2013 12:00pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6731 |
I noticed the other night that the left hand temp dial is a fair bit dimmer that the right hand side, so I wonder if this is repairable by replacing the control board with the LEDs on it? Got - 2017 SDV8 Autobiography in Loire Blue
1st Mar 2013 9:56am |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
Typically, the resistance of the "dimmer" is used in the PWM circuit to determine pulse width. You don't dim LEDs using a resistor, you dim them by sending pulses of full voltage; the wider the pulses, the brighter the LED appears. Pulse Width Modulation. Otherwise, you have to dump the heat generated by the variable resistor. Old school. Jim 2000 NAS HSE 2005 NAS HSE |
1st Mar 2013 10:59pm |
