![]() | Home > eBay & Bargain Spots > Bargain battery pricing |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Was looking into batteries today and the Varta i1 is exactly the same as the Bosch S5.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
nice find John..the only advantage of buying from ECP is , if live close to a depot you can take it back if/when it fails.. ... - .- -.
Hmm, wonder if my brother would be able to pop by and pick one up next time he is passing |
Mines original John but can't vouch for full details till i get home other than its 800something CCA and 95AH rating off the top of my head |
Cheers KP, they should have a number like 017 or similar.
Just back from a 15 mile test drive and no faults showed. Does this mean the battery was at fault which would be my guess and an obvious first choice. I'm not 100% sure but reading on the forum about the HDC & Suspension Inactive faults seems to show that it can be either a battery problem of one of the following:- Speed/ABS sensor, ABS module, wiring or connections. If however it was one of these faults then surely it would throw up the fault more or less straight away...
WTF have I done to upset you now bawbag? |
Nowt , just thought i would welcome you back seeing as you have not been on for a few days …..
Part number 017SP
Thanks KP, that confirms my thoughts that the 017 I fitted today will be fine for the time being allowing me to monitor the situation before splashing out on a new battery.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
Inran around in my tdv8 for a couple of months with an 017, was fine, just didnt like excessive use of the fbh. There is nothing that can't be fixed with a hammer😜😜
As above, mine doesn't like more than 20mins of fbh use these days |
Had to go to the other side of town tonight, I was less than 100 yards into the journey when 'bong'...my heart sank, then noticed it was the low temperature warning, stopped when I arrived at my destination, restarted and another low temperature bong. No HDC or Suspension inactive faults. Will see what tomorrow brings |
