To charge the battery/run the fridge, you will need either 13 pin or 12n/12s white and black plugs on the car.
All the adaptors do is change the format they dont add or remove any functions. If you have only 7 pin black on the car and put a 7-13 pin adaptor into it you will only get lights, no charging etc.
For that you need the 2 white and black leads in to a 13pin socket and plug van into that.
If you have a 13 pin socket on the car you can get an adaptor which turns that into 12n and 12s.
Clear as mud? There is nothing that can't be fixed with a hammer😜😜
