Home > Technical (L322) > could some one id this part for me
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi Gents
Now as my RR has been running like a dog I finally went under the bonnet and had a look around I removed the box thing over the engine and found this hose at the back of the engine, Am I right in saying it's a breather hose of some sorts or something to do with the air flow (I know sod all about cars but want to learn). either way even I know that this should not be like this, this being marsh mellow feel with a great big tear in it. It would be great if I could be told what this does what would be the effect on engine performance in this state and most importantly a part number if poss..
I have taken some shots of the hose not sure how to get them on here though Rolling Eyes
many thanks for any help
Post #12973 11th Feb 2010 1:58pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Defo need pics to help,
upload them to photobucket or a similar site and add the link or URL in your thread Thumbs Up TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #12976 11th Feb 2010 2:07pm
kb5
thanks for that I hope this works ...
http://www.flickr.com/photos/47422900@N03/
Bow down
Post #12981 11th Feb 2010 2:31pm
dan_uk_1984
PCV Hose, there are 2 (3) of them. Two over the top go into an oil separator cyclone at the back left hand side of the engine and then a small third hose runs down from that onto a metal pipe that runs into the sump.
The BMW hose is not oil resistant so it just melts after a few years.
Do a search for PCV Hose and you'll see the writeup I did a while back.
http://www.fullfatrr.com/forum/topic670.html?highlight=pcv+hose
Post #12982 11th Feb 2010 2:49pm
kb5
Spot on exactly the hoses I was talking about ... Thanks ... I read your previous post and read you were getting a engine warning light come, I haven't had this I have had the car sounding like its gasping for air and only doing around 11mpg which is costing me a small fortune .. Do you have any idea what other problems this could cause as I am now as you may see in other posts having problems with staying in D etc sure not related but thought I would ask...
Post #12985 11th Feb 2010 3:14pm
dan_uk_1984
I cant see it causing any problems with the gearbox shifting....
Problems associated with an open PCV system include:
    Water in the oil from sucking in too much air into the crankcase.
    Blowing all of your oil out when the water in the oil freezes solid in the rest of the PCV system or oil pathways.
    Poor, erratic idle and stalling.
    Terrible fuel economy, as you've already found.
Dan
Post #12986 11th Feb 2010 3:19pm
M44K TS
When you say terrible fuel economy, how bad are you talking? Mine's averaging between 15-17mpg under normal driving, (4.4 VCool Wonder if it's worth me taking a look at my pcv hoses.
Post #12990 11th Feb 2010 4:33pm
Vogue
15-17mpg under normal driving, I think thats about normal / a good return Wink
Post #12992 11th Feb 2010 4:42pm
dan_uk_1984
I get 17/22 on petrol, 15/17 on LPG
If you've not looked at the hoses then it's worth checking, this is a problem that happens on EVERY bmw M62 engine due to the type of rubber they use.
Post #12993 11th Feb 2010 4:48pm
Vogue
blimey Dan 17 to 22 on Petrol is fantastic Thumbs Up - is it still worth the conversion to LPG if it drops by 5 mpg?
Post #13001 11th Feb 2010 5:09pm
M44K TS
I'd expected it to be around 17mpg as the norm, infact, it's exactly the same consumption as I was getting on the Maserati.
Post #13002 11th Feb 2010 5:17pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
at the current petrol prices and if you are going to keep the car at least 18 months defo.
best money i ever spent on the rangy.
Post #13102 12th Feb 2010 10:48pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I currently get 16.9mpg on gas Hilarious at 51ppl.
Over double less the 5%
Still great for that V8 sound. 15MY SDV8 Vogue SE
Post #13104 12th Feb 2010 10:57pm
