![]() | Home > In Car Electronics (L322) > Airbag warning light after about 25 mins of driving |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Getting used to sending the car into the garage for 1 repair to be fixed only for it to be returned with more...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35493 ![]() ![]() |
there's a airbag pad under the seat leather so it could have been damaged when the heated seat was repaired or the connection is loose.. ... - .- -.
can you not reset the tpms via the menu to a lower psi .. ... - .- -.
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Didn't realise they were adjustable.....I'll have a look, cheers Stan 2007 TDV8 Vogue SE Java Black |
t'was a question not an answer.... |
seriously though, the bmw x5 has this feature but i'm unsure if the fullfat has... ... - .- -.
Thanks Stan - any idea why it will only come on after about 20 mins - it's pretty consistent. |
not sure why 20 mins is the cut off point, maybe some part of your journey where you might move on the seat causing the fault or do you have the heated seat on and at that time it switches off..could be anything really... ... - .- -.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
This is a total guess, but heated seat sometimes have a timer. Could that be causing it? |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Logic does say it will be connected to the seat being removed, first port of call is to check all the connections at the base of the seat. Does the heated part now work ok? When I was doing my seat refurb, the only time I caused a warning light to come on was when I disconnected a seat with the battery connected, but that resulted in the airbag being on all the time. I did have an intermittent warning light but since changing the battery it has never come on. It was disconnecting the seat belt tensioner that started my warning light off. Hope that helps. One day your life will flash before your eyes......................................make sure yours is worth watching!
Many thanks to all - it's heading back to the garage to sort and I will update when we have a solution!
Just pulled up outside my house tonight and the bloody airbag light came on !!!!! |
