Home > Technical (L322) > Radio not working!
davidalanbatt
2003 Range Rover Vogue Td6 Zermatt Silver
Radio not working!
Since I recharged and refitted the battery to my 2002 3.0 diesel the radio has stopped working. Then car is starting fine now and the unit is the standard single CD/radio unit (no satnav). The display for the radio does not come on. When I attempt to switch it on it just says PHONE on the display. There is no volume but the computer functions such as mpg work as normal. I have tried removing and refitting fuses 8 & 49 but no luck. Crying or Very sad
Any ideas guys?
Thanks again!
Post #12898 10th Feb 2010 5:36pm
SteveMFr
Site Sponsor
The display is actually a multi-information-display (MID) and not an integral part of the radio - it just displays the radio info as well as the other vehicle info. The radio/cd player are one unit.
I'd have to check wiring to see exactly which fuses are relevant, but if all else fails...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #12900 10th Feb 2010 6:03pm
davidalanbatt
I started the car this evening and the radio came back into life! Laughing
Post #13019 11th Feb 2010 7:38pm
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
In mine, RR TD6 2004 vogue, the radio module in the back has its own 10 amp fuse.
Further more it has a AMP located next to the radio module and I had a problem once with water-humidity on the sockets which caused failure of the audit system: no volume.
Post #13020 11th Feb 2010 7:44pm
