Home > Technical (L322) > anyone familiar with the front hubs? |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Hi all.
28th Jan 2013 10:29pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
An engineering shop may be able to help you if you get the hub off. One day your life will flash before your eyes......................................make sure yours is worth watching!
28th Jan 2013 10:33pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3957 |
Why not grind the disc around the bolt until you can remove the disc and then remove the remains of the bolt with Molegrips or similar.
28th Jan 2013 11:13pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6401 |
Do you mean the grub screw that holds the disc onto the hub?
29th Jan 2013 12:00am |
^^^ That will be number 9 then....no not that number nine
29th Jan 2013 12:33am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
A good engineering shop with a spark eroder will get it out without damaging the threads |
29th Jan 2013 1:27am |
Hi gents,
29th Jan 2013 8:56am |
Hi Woodie, if you grind the 9 bolt flush with the hub, you should be fine as I agree with the above, you don't need it. It only helps keeping the disc in place while you mount the wheel.
29th Jan 2013 9:11am |
Workshop Manual , with pictures from here,
29th Jan 2013 9:54am |
If the disc is solid enough, then as long as its not my dust shield, which it shouldn't be as I just fixed it with penny washers, it must me Tue long bolt I've broken off catching inside of the hub somewhere. What is really like to know is if I can access the back of bolt 9 when the hub is removed, other wise its going to be a new hub. MY2010 TDV8 Vogue Ipanema Sand
29th Jan 2013 10:31am |
