Home > LPG > LPG Cut out whilst driving!!
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
04 vogue using a Prinns VSI lpg system.
Yesterday after driving about six miles with a almost full tank of LPG it started bleeping and converted back to petrol. I dont know why? It would not let me turn the lpg back on. So got to where i was going, turned off, had lunch, three hours later started it up and drove home on gas no problem. Any ideas what this little problem was? Gone:
Golf GT TDI 150- Still got.
BMW 325TD
Range Rover Classic
Defender 90
Post #166234 21st Jan 2013 12:09pm
DMRR
Temperature? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #166235 21st Jan 2013 12:13pm
Just been reading about people's valves freezing in this weather. Previously..
Post #166236 21st Jan 2013 12:14pm
ebajema
Most likely frost of the LPG that stopped it. The warm engine kept everything fine. If you can switch to petrol manually, leave it on petrol for a bit longer, till the engine warms up a bit and then switch to LPG.
Check with a good LPG installer what could be the issue and see if it can be resolved easily. MY 2010 5.0 SC Galway green and sand interior!!
Post #166246 21st Jan 2013 1:07pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I used to have one that was electronically heated, as well with the cooling water, the best result out of LPG is at a constant temperature
Post #166259 21st Jan 2013 2:00pm
ebajema
Indeed, if it has electric heating while the cooling water warms up, that is the best. LPG needs heat to evaporate. I remember an older installation that if you didn't get it to fire on the first go, you would be screwed. And that of course happened to me the very first time I drove that car (Porsche 914) in the winter. MY 2010 5.0 SC Galway green and sand interior!!
Post #166270 21st Jan 2013 2:35pm
ChrisR
United Kingdom 2005 Range Rover Vogue 4.4 V8 Tonga Green
Yep mine does that, just needs a slightly longer run on petrol to warm up then its fine.
Chris Life should be a journey to the grave with the intention of arriving skidding in sideways, Merlot in one hand, Cigar in the other, body thoroughly used up, totally worn out and screaming WOO HOO what a ride!
Post #166282 21st Jan 2013 3:04pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
same here and my fuel gauge goes nuts in this cold weather aswell
Post #166294 21st Jan 2013 3:41pm
oliver9627
Cheers for all of the replies. A great help. Gone:
BMW 325TD
Range Rover Classic
Defender 90
Post #166336 21st Jan 2013 5:59pm
steptoe
Re: LPG Cut out whilst driving!!
I'm running Prinns on my 2002 Vogue. Turn the ignition off and restart the car. You'll find the LPG will work again.
Happens with my LPG every now and again. Even in warm weather and usually when the LPG tank is full or nearly full.
Post #166413 21st Jan 2013 10:41pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Had this as well - easy fix, its a sticky solenoid valve (front) at the reducer and is fairly common. I pulled mine apart and cleaned the residue from the plunger, rebuilt it and it has been fine since..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #166417 21st Jan 2013 11:01pm
