Home > In Car Electronics (L322) > Tailgate interior lights
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Hi guys I've just changed some interior lights and I have no lights whatsoever in the tailgate or boot space I've had a look through the manual and checked the reccomended fuses but I can't find anything I also don't have any number plate lights and I've just noticed that my sunroof now won't auto close
Please someone help!!! F**K IT you only live once
Post #165924 19th Jan 2013 5:18pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
What type did you change them for, sounds like you have shorted out a connection
Which is very easy when putting the reflector cover back on them
There are no fuses for the rear boot lights so you have to lock the car and retry in 30 mins
If still no good disconnect battery for ten mins and try that RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #165927 19th Jan 2013 5:25pm
stuboy00
Jr :- I changed the lights for LED's working fine in the passenger cabin just not in the tailgate, will give your suggestion a try
Stan :- I have the same thoughts as you I may need to sift through all the fuses one by one ?? F**K IT you only live once
Post #165929 19th Jan 2013 5:29pm
sorry Stu my post was accidently deleted by me...
as JR said you might have caused some fuses to blow when doing the lights. ... - .- -.
Post #165930 19th Jan 2013 5:34pm
Googsy
Have you got bulbs in correct way as they are polarity sensitive. Do old bulbs still work? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #165931 19th Jan 2013 5:50pm
stuboy00
Rolling with laughter not often a moderator moderates them selfs F**K IT you only live once
Post #165932 19th Jan 2013 5:53pm
Have you tried closing and opening the tailgate?
Post #165933 19th Jan 2013 5:57pm
stuboy00
Googsy :- yea got them round the correct way also not changed the festoon in the boot itself but that light isn't working that's how I know there's something wrong F**K IT you only live once
Post #165934 19th Jan 2013 5:57pm
stuboy00
Niceday :- that was the first thing I tried but thanks for the suggestion F**K IT you only live once
Post #165935 19th Jan 2013 6:04pm
The luggage space light and the tailgate lights are switched by a switch incorporated in the tailgate lock, it serves nothing else.
If you remove the luggage space light, determine which connection is the earth and earth it with a piece of wire to a luggage tie down loop on the boot floor your lights may light up.
Close the tailgate and open before doing this. Thumbs Up
Post #165936 19th Jan 2013 6:11pm
stuboy00
Thanks for all the advise guys
Jr:- you were correct just left it for a bit then when I went back to it all is working again Bow down
Cheers fella F**K IT you only live once
Post #165937 19th Jan 2013 6:18pm
Jr-auto-electrics
Not a problem stuboy
Auto reseting thermal contacts little Censored
smart little things those LCMs RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #165944 19th Jan 2013 7:10pm
Jr-auto-electrics
Stuboy take a look at my Flickr pics of boot lights
If you like I can do you a set RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #165950 19th Jan 2013 7:25pm
stuboy00
Hi jr thanks your lights look awesome and so does the range but the lights I installed are pretty good Thumbs Up F**K IT you only live once
Post #165966 19th Jan 2013 8:53pm
