Home > Technical (L322) > Steering wheel probs. (update)
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Can you pull it out or push it in ? You will need to try quite hard, if so the nut is on its last legs One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #165708 18th Jan 2013 4:37pm
out/in - up/down - everything works fine again - but i will get the nuts from Ulli anyway ..... Smile All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #165718 18th Jan 2013 4:53pm
JohnnyDangerous
No, can YOU manually pull it out towards you? It should be solid. Mine I can pull out or push in. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #165720 18th Jan 2013 4:55pm
i never could pull it MANUALLY out or in before. All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #165799 18th Jan 2013 9:45pm
JohnnyDangerous
When the nut lets go you can normally just pull the threads of the adjusting motor through it as there are no threads in the nut left. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #165825 18th Jan 2013 11:34pm
I am a bit slow - i see what you mean i try it later (bit scared) Sad All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #165835 19th Jan 2013 7:42am
ebajema
Hi Angel, I would suggest to first get Uli's nuts (pun intended) and then try to rip the last threads out !! MY 2010 5.0 SC Galway green and sand interior!!
Post #165843 19th Jan 2013 8:50am
Laughing OK Wink
well i tried it today - i cant move it manually Smile All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #165852 19th Jan 2013 9:14am
