Home > Technical (L322) > Steering wheel probs. (update) |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Can you pull it out or push it in ? You will need to try quite hard, if so the nut is on its last legs One day your life will flash before your eyes......................................make sure yours is worth watching!
18th Jan 2013 4:37pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
out/in - up/down - everything works fine again - but i will get the nuts from Ulli anyway ..... All my spelling errorz are belong to me!
18th Jan 2013 4:53pm |
No, can YOU manually pull it out towards you? It should be solid. Mine I can pull out or push in. One day your life will flash before your eyes......................................make sure yours is worth watching!
18th Jan 2013 4:55pm |
i never could pull it MANUALLY out or in before. All my spelling errorz are belong to me!
18th Jan 2013 9:45pm |
When the nut lets go you can normally just pull the threads of the adjusting motor through it as there are no threads in the nut left. One day your life will flash before your eyes......................................make sure yours is worth watching!
18th Jan 2013 11:34pm |
I am a bit slow - i see what you mean i try it later (bit scared) All my spelling errorz are belong to me!
19th Jan 2013 7:42am |
OK
19th Jan 2013 9:14am |
