Home > Technical (L322) > Smoke from filler cap!
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Iv just looked at the online manual In the 'manifold and exhaust system td6'and I can't see any breather pipes, this must be the correct section is it?
Post #163201 9th Jan 2013 9:55pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Yes the back left of the engine. Have a look tonmorrow and you will see what I mean. Sorry no link online, but do a search here for.pcv repair and somewhere there is a link to a video of a yank mechanic swapping the pcv, but I don't think he goes as far as the metal pipe . You will see it bolted to the bottom of the sump with a banjo or you will see the top of it from the back left of the engine once the cyclone/ condensor is moved. It's fairly simple once you get eyes on it. Only trouble is you have tobdrop engine oil to get the metal drain pipe off it it does turn out to be blocked MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #163203 9th Jan 2013 10:00pm
Durham4416
Ok I see, iv replaced a crankcase breather for the later style vortex type on my 320cd in the past so I will be able get that far, so once I remove the crankcase breather in looking for a metal pipe that goes from the bottoms of the housing to the sump, then if I try blowing down this pipe and I can hear the oil 'gurgle' then its clear, if its blocked I need to two over and clean out? Think iv got it, you mentioned a few other pipes aswell, do these also run from the crankcase breather housing? Thanks
Post #163208 9th Jan 2013 10:06pm
woodchopper23
Look at this link
http://www.fullfatrr.com/forum/post152051.html#152051
Follow the links within links and you will find the pictures. Its worth reading from when I changed all mine and some good blokes sent me the links MY2010 TDV8 Vogue Ipanema Sand
Post #163210 9th Jan 2013 10:14pm
woodchopper23
I've found it from the pcv wiki
http://www.fullfatrr.com/forum/topic670.html
There is a cracking line picture if the metal pipe in it.
You will see it now MY2010 TDV8 Vogue Ipanema Sand
Post #163211 9th Jan 2013 10:18pm
woodchopper23
The filthy pipe is labeled as 6n 664 in the drawing.
I should really learn more about posting pictures up !
Just remember before your drain your engine oil out or anything drastic, mine's q petrol so just check your pcv is the same as petrol . MY2010 TDV8 Vogue Ipanema Sand
Post #163212 9th Jan 2013 10:20pm
The TD6 doesn't have a PCV
Post #163222 9th Jan 2013 10:35pm
woodchopper23
Big Cry MY2010 TDV8 Vogue Ipanema Sand
Post #163223 9th Jan 2013 10:36pm
Durham4416
Ah. Is it worth checking the crankcase breather and pipes coming and going from it still though? Although an awkward job it seemed more inviting than a head gasket or worn piston rings Sad
Post #163224 9th Jan 2013 10:42pm
