![]() | Home > In Car Electronics (L322) > Easiest place to pick up +ve on ign feed |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Definately going to fit a camera front and rear for safety sake, wheres the easiest place to hardwire it with an ign feed as I dont want to just plug it in to the cigar lighter. One day your life will flash before your eyes......................................make sure yours is worth watching!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Believe it is all live all the time in the rear fusebox, but there is an ignition feed on the other side, to the radio, that you can tap into.
Thanks the +ve needs to be in the front of the car, sort of under the steering wheel or gear surround its low draw so Ill have a poke around, just wondered if there was anywhere easy to use. One day your life will flash before your eyes......................................make sure yours is worth watching!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
Mine is still plugged into the cig lighter which was only supposed to be temporary |
Thanks Alistair, that looks pretty simple and the piggyback fuse means no cutting needed, just need to try and get a lead to the back of the car for the rear facing lens, could have done with this in the summer as I almost got arrested. One day your life will flash before your eyes......................................make sure yours is worth watching!
