![]() | Home > General > How to store car for longer periods |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hi Folks - Not actually about the RR but my other car but I think the same would apply. I don't use it that often and continually have a flat battery (after 5 or 6 weeks of non use) so want to know the best way to store it. Should I disconnect the pos or neg terminal to the battery until I want to use it or does it not matter which.
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
That would be fine you should always disconnect the neg terminal first or if you touch the body with the spanner still touching the pos terminal you would cause a short circuit large bang and flash which could cause damage to you the spanner and all the electrical circuits
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 ![]() ![]() ![]() |
Or hook it up to a trickle charger would be another option. Lloyd Barnes
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
With my M5, I did about 1000 miles the last year I had it. The battery was under the rear seat, so I run a mains lead (like the one on a kettle or a PC) into the boot. I then put the female bit onto my trickle charger and connected them up easily in the boot. The boot still shut OK and the car was topped up as needed.
Depends what the car is and where its going to be stored. If its inside then i'd ensure its cleaned really well and waxed and gloss to hell then raise it off its wheels and let the tyres down a little so as not to stretch them anymore, protect the tyre walls with tyre shine stuff and all the rubber seals. Then disconnect the battery and still use a trickle charger but also get a battery jacket on it too |
PS any battery that can be charged should be fully charged when its not going to be used for a while regardless of what type it is as its just best practice |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
How long are your leaving it?
Thanks for the replies guys. It's actually my Mercedes CLK Cabriolet. Like Fox, I don;t use it in the winter months much but do on occasion take it out if it's dry and bright.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Kingpleb, when I'm a billionaire I'm going to get you to maintain my car collection. |
Cheers fella |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I would definately use somethiing like an Optimate charger, this only charges when needed so is a fit and forget item, give the car a good clean and grease any parts likely to seize up. One day your life will flash before your eyes......................................make sure yours is worth watching!
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I keep a C-Tek on my Rover and have done for the past 9 years and it works a treat. |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I use one of these for my, motor bikes, The TVR when i had it.
I have an optimate for my bikes which aren't really used in winter. They're wired in so it's a simple plug in connection. |
