Home > In Car Electronics (L322) > Aftermarket camera no colour?
Page 1 of 3 123>
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Ok so I've just fitted my new camera all connections are good soldered and taped everything wired up as should be but when I select the camera it appears in black and white? Now i'm not sure if this is correct cause my reverse camera has never worked the new camera is colour and HD so im pretty lost
Any help is appreciated
Cheers stu F**K IT you only live once
Post #160406 29th Dec 2012 12:46pm
Is it PAL or NTSC ?
Post #160409 29th Dec 2012 1:16pm
stuboy00
It's an NTSC so now I'm guessing I've got the wrong one lol F**K IT you only live once
Post #160410 29th Dec 2012 1:18pm
I think so, but not certain....
It would certainly explain it being B&W.
The only other possible cause is low light level, some colour cameras automatically switch to B&W in lower light levels.
Post #160411 29th Dec 2012 1:21pm
Actually, a quick search says NTSC, so may be low light levels - or it's a PAL camera in the wrong box......
Post #160412 29th Dec 2012 1:28pm
stuboy00
Hi alistair think it might be the later as the light levels are pretty good here at the moment so it's quite possible it's been the wrong camera i will get in touch with the supplier and see what happens
Cheers for the quck reply and advise F**K IT you only live once
Post #160414 29th Dec 2012 2:22pm
stuboy00
Ok so just got back home and read the paperwork for the camera and it says PAL/NTSC does this mean its compatible either way? I'm really bamboozled now!!!! F**K IT you only live once
Post #160426 29th Dec 2012 4:57pm
Do you have the touchscreen Stu? Have you tried the 753 menu for testing? Can you select pal or NTSC in there for testing? Previously..
Post #160428 29th Dec 2012 5:00pm
stuboy00
Yea got touch screen I'm just going to try it just now wish me luck lol F**K IT you only live once
Post #160430 29th Dec 2012 5:06pm
stuboy00
Ok so in the car configuration it's colour on PAL can I change the touch screen to PAL on any settings? Or would I need to use an iid ? F**K IT you only live once
Post #160431 29th Dec 2012 5:13pm
So, you can see it in colour in the 753 menu, but not in normal use, is that right? Have you checked the wiring diagram for the camera, is there a link or whatever to enable pal or NTSC by default? Previously..
Post #160433 29th Dec 2012 5:24pm
stuboy00
Yes on the test it's colour but when selected by reversing it B&W there is no way of changing from one to the other and there is no info on the instructions just a wiring diagram?
Post #160434 29th Dec 2012 5:29pm
If it works fine in test when you click on PAL then it looks like you defo have it set up for pal, but you need it set up for NTSC. If the camera does both there must be a way of changing it. If you can't see a link or wiring diagram you will have to google the camera make and hopefully see how to set it to NTSC... If you can that is!!!! I don't know if it is possible to set the car to default to either NTSC or PAL sorry. Previously..
Post #160436 29th Dec 2012 5:41pm
stuboy00
Thanks for the help contraband can't really find out much online when I type in the model number they all say NTSC so I've contacted the supplier just need to wait and see what will be?
Post #160437 29th Dec 2012 6:06pm
Uk works on the PAL system, if you have an NTSC camera it won't display correctly.
NTSC stands for National Television Standards Committee. PAL stands for Phase Alternating Line. NTSC is the standard broadcast format in the United States, while PAL is the standard broadcast format in Europe, Australia, and parts of Asia.
The other main difference between NTSC and PAL is resolution quality. While PAL produces fewer frames per second than NTSC, it produces more lines. An NTSC television will broadcast 525 lines of resolution, while a PAL television will broadcast 625 lines of resolution. As the lines of resolution increase, so does the amount of visual information. This produces better picture quality and screen resolution. If you were to try to convert an NTSC movie to PAL, black bars would most likely be added to compensate for the smaller screen aspect. The black bars would resemble what you would see in a widescreen or letterbox movie.
NTSC will display (albeit in B&W) on a PAL system but PAL will not display on an NTSC system.
There are converters available which will change the system, might be worth looking to see if they are available for your camera
Post #160440 29th Dec 2012 6:37pm
Page 1 of 3 123>
