Home > In Car Electronics (L322) > Aftermarket camera no colour? |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 |
Ok so I've just fitted my new camera all connections are good soldered and taped everything wired up as should be but when I select the camera it appears in black and white? Now i'm not sure if this is correct cause my reverse camera has never worked the new camera is colour and HD so im pretty lost
29th Dec 2012 12:46pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7953 |
Is it PAL or NTSC ? |
29th Dec 2012 1:16pm |
It's an NTSC so now I'm guessing I've got the wrong one lol F**K IT you only live once |
29th Dec 2012 1:18pm |
Actually, a quick search says NTSC, so may be low light levels - or it's a PAL camera in the wrong box...... |
29th Dec 2012 1:28pm |
Hi alistair think it might be the later as the light levels are pretty good here at the moment so it's quite possible it's been the wrong camera i will get in touch with the supplier and see what happens
29th Dec 2012 2:22pm |
Ok so just got back home and read the paperwork for the camera and it says PAL/NTSC does this mean its compatible either way? I'm really bamboozled now!!!! F**K IT you only live once |
29th Dec 2012 4:57pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Do you have the touchscreen Stu? Have you tried the 753 menu for testing? Can you select pal or NTSC in there for testing? Previously..
29th Dec 2012 5:00pm |
Yea got touch screen I'm just going to try it just now wish me luck lol F**K IT you only live once |
29th Dec 2012 5:06pm |
Ok so in the car configuration it's colour on PAL can I change the touch screen to PAL on any settings? Or would I need to use an iid ? F**K IT you only live once |
29th Dec 2012 5:13pm |
So, you can see it in colour in the 753 menu, but not in normal use, is that right? Have you checked the wiring diagram for the camera, is there a link or whatever to enable pal or NTSC by default? Previously..
29th Dec 2012 5:24pm |
Yes on the test it's colour but when selected by reversing it B&W there is no way of changing from one to the other and there is no info on the instructions just a wiring diagram?
29th Dec 2012 5:29pm |
If it works fine in test when you click on PAL then it looks like you defo have it set up for pal, but you need it set up for NTSC. If the camera does both there must be a way of changing it. If you can't see a link or wiring diagram you will have to google the camera make and hopefully see how to set it to NTSC... If you can that is!!!! I don't know if it is possible to set the car to default to either NTSC or PAL sorry. Previously..
29th Dec 2012 5:41pm |
Thanks for the help contraband can't really find out much online when I type in the model number they all say NTSC so I've contacted the supplier just need to wait and see what will be?
29th Dec 2012 6:06pm |
Uk works on the PAL system, if you have an NTSC camera it won't display correctly.
29th Dec 2012 6:37pm |
