Home > In Car Electronics (L322) > REAR SCREENS
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
REAR SCREENS
HI GUYS, dont expect there will be many peeps about due to crimbo around the corner, Sad but thought i would post anyway. i did ask this question earlier on another post but diden't really draw much conclusions from it so thought i would re phrase the question.
re vogue on a 54 plate, does anyone know what screens were fitted to this year at factory Question i dont know if mine are a factory fit or not. the name on them is NECVOX. so trying to match what wireless phones i need Question does anyone have these screen fitted Question Thumbs Up
bob
Post #159514 23rd Dec 2012 12:29pm
They sound aftermatket to me, the vogue would not have had screens as standard, would have to be an Vogue se (probably gping to get shot down with corrections) have seen some necvox ones for sale as a kit with the headphones, and it says they come with a wireless transmitter, check you have this installed, but a google of NECVOX INFRARED HEADPHONES will probably yield some results. There is nothing that can't be fixed with a hammer😜😜
Post #159529 23rd Dec 2012 1:20pm
BOBCUSSEN
ok thanks for that info. i will have a look around the boot to see where that is likely to be fitted
thanks
bob
Post #159540 23rd Dec 2012 1:38pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
my old 2004 vogue had aftermarket necvox screens in the headrest and the earphones were also labled necvox. My current 2005 vogue se has factory fit screens with 6 disc changer in the boot and can be controlled from the front touchscreen Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #159614 23rd Dec 2012 7:58pm
BOBCUSSEN
HI MARSIE
thank for the reply, i will have a look today to see if i can find the module in the boot. the earphones were not in the car when i bought it, but looking on the internet it does not seem expensive to buy a pair inc the transmitter whatever it is, that would be compatible with these screens so i will see what is about. it is also wired to take playstation as well. i also have the touchscreen denso system but there is no facility to control the rear screens, so only from the remotes
Post #159769 24th Dec 2012 9:37am
noddy5vogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
my transmitter is fitted on the roof headlining at the rear of car , i just thought it was something to do with the alarm
Post #159824 24th Dec 2012 1:52pm
BOBCUSSEN
HI noddy
thanks for that info. will take a look at mine. not thought of looking there
bob
Post #159916 24th Dec 2012 5:45pm
alz4321
2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Mine are necvox, it has a multichanger in the boot and the transmitter is stuffed in with the wiring in the boot by the sat nav etc. I also don't have the headphones for them but from what I remember you should be able to plug any transmitter in. I'm not going to be using the changer as I'm connecting the screens up to the aftermarket stereo in the front so I've not tried my theory of any transmitter working.
Post #159928 24th Dec 2012 6:06pm
broncoupe
Rolling with laughter
Necvox screens don't have built in transmitters, these screens were really common 04 to 08
2 options both types will be cordless
FM transmitter type if its an early car Philips units were common usually mounted in the boot or side panels will work with any RF headphones
Infrared these transmitters need line of sight so will usually be headlining front or rear occasionally I have mounted them in the panel in the centre of the roof and drilled little holes to allow the LEDs to poke through
Again any infra red headphones will work single or dual channel
Regards
Post #164784 14th Jan 2013 8:43pm
