![]() | Home > In Car Electronics (L322) > REAR SCREENS |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI GUYS, dont expect there will be many peeps about due to crimbo around the corner, |
ok thanks for that info. i will have a look around the boot to see where that is likely to be fitted
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
my old 2004 vogue had aftermarket necvox screens in the headrest and the earphones were also labled necvox. My current 2005 vogue se has factory fit screens with 6 disc changer in the boot and can be controlled from the front touchscreen |
HI MARSIE
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
my transmitter is fitted on the roof headlining at the rear of car , i just thought it was something to do with the alarm |
HI noddy
alz4321 Member Since: 09 Dec 2012 Location: Wales Posts: 18 ![]() ![]() |
Mine are necvox, it has a multichanger in the boot and the transmitter is stuffed in with the wiring in the boot by the sat nav etc. I also don't have the headphones for them but from what I remember you should be able to plug any transmitter in. I'm not going to be using the changer as I'm connecting the screens up to the aftermarket stereo in the front so I've not tried my theory of any transmitter working. |
broncoupe Member Since: 21 Nov 2011 Location: bournemouth Posts: 70 ![]() |
