Home > Maintenance & Mods (L322) > Java black is not very black
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Sad
My Java Black TD6 paint looks a little faded, she does pick up a lot of crap from the roads round here, and lives in a dusty gravel car park most days so she'll never been concours condition. But, is there anything I can use to bring back the black she once had?
Many moons ago in my youth I'd use T-Cut Colour Fast, but guess that frowned upon these days? Not looking to fully detail her, just bring back a bit of proper colour.
Any suggestions? Will be going over her with a clay bar first, once she's had a proper wash (and not from the local Albanian lads)
Post #158850 20th Dec 2012 8:46pm
I use a clay, then i there are any scratches; farecla g3, then zymol. Comes out shiny... There is nothing that can't be fixed with a hammer😜😜
Post #158920 20th Dec 2012 11:36pm
simon1233
How long is a piece of string? You are on the precipice of a steep cliff here Smile
To get the paintwork looking a deep glossy black again properly you need to wash, then clay, then wash again, dry, then polish with a DA (or rotary machine dependant on levels of skill/experience/bravery), buff and finally apply a coat of a good wax...
If you are wanting a slightly (only slightly mind) easier option then cleaning (use something like fairy liquid to strip away all the old residues of wax etc) and claying the car is essential (factor in a good few hours for this as these are very big cars) and then use something like Autoglym Super Resin polish. This contains some fillers and masking agents which will 'fill' the fine scratches which make the paintwork appear dull and could give you an improved result Thumbs Up I hear that Poorboys Black hole polish is very good on black cars but I have never used it myself. I found that the Autoglym SRP does a good enough job, but cannot compare to using a DA with the proper pads/compounds.
When I got my car it was covered in 'buffer trails' which after 3 trips to the body shop (at the dealers expense) were not really improved. I bought a 'cheap' Kestrel DA machine with Meguiars pads and compounds and detailed the car myself. Took the best part of 12 hours but the paintwork has no holograms or buffer trails anymore Thumbs Up
Post #158937 21st Dec 2012 12:46am
simon1233
This may be educational for you Rolling with laughter Rolling with laughter
http://www.stuttgart9.co.uk/forum/car-deta...alert.html
Post #158939 21st Dec 2012 12:51am
there's a good read in our wiki re detailing.. ... - .- -.
Post #158948 21st Dec 2012 9:36am
klf400
you could try the new autoglym paint pro system , i have seen it used and the results are amazing , i will be using it on my ff when i get time gonna do my 2010 conversion first
check this out  1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #159198 22nd Dec 2012 11:05am
Turbo Tony
Definitely clay, then perhaps try Prima Amigo glaze.
It's a glaze with a darkening effect which adds some depth to the colour again. It should be topped with a wax/sealant, as it has very few protective properties, but it's a great product. Researching my first Range Rover purchase
Post #159221 22nd Dec 2012 3:56pm
